http://www.toyodiy.com/parts/p_U_198...PVFA_2211.html
on that link it shows 23809 like a U shaped fuel line support thingy. I know where the top goes, but where does the other lead to? |
It goes to the fuel tank return hardline. 77277a is the hose which joins that to the hardline:
http://www.cygnusx1.net/Supra/Librar...spx?F=7701&P=2 |
ok i will find that hardline, I see that it is being covered by that plastic cover which i have seen under my car, if i follow the hardlines outta there i should find the one that goes to it :S
There is a supply and a return which both come out at the same junction, make sure you connect to the right one. They both exit near the rear mount of the lower A arm... kind of hard to spot as they sit above the level of the subframe.
Changing the Power steering pressure line w/pics! | Mahonri | MKIII Supra | 4 | 06-01-2009 11:37 AM |
Removing carbon canister, fuel evap. emissions | pdogg | Non-Generation Specific Questions | 2 | 09-17-2008 06:58 AM |
Testing for bad ECU, &/or bad Fuel Pump | elliotl | MKIII Supra | 0 | 08-21-2007 10:42 PM |
Fuel line problem | Damian | MKIII Supra | 1 | 07-23-2005 10:22 PM |
