Old 10-29-2009, 03:58 PM   #1
dannydavi
dannydavi's Avatar
Default Fuel Line?
http://www.toyodiy.com/parts/p_U_198...PVFA_2211.html
on that link it shows 23809 like a U shaped fuel line support thingy. I know where the top goes, but where does the other lead to?
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 10-29-2009, 08:03 PM   #2
It goes to the fuel tank return hardline. 77277a is the hose which joins that to the hardline:
http://www.cygnusx1.net/Supra/Librar...spx?F=7701&P=2
Old 10-29-2009, 08:06 PM   #3
dannydavi
dannydavi's Avatar
ok i will find that hardline, I see that it is being covered by that plastic cover which i have seen under my car, if i follow the hardlines outta there i should find the one that goes to it :S
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 10-29-2009, 08:16 PM   #4
There is a supply and a return which both come out at the same junction, make sure you connect to the right one. They both exit near the rear mount of the lower A arm... kind of hard to spot as they sit above the level of the subframe.
Changing the Power steering pressure line w/pics! Mahonri MKIII Supra 4 06-01-2009 11:37 AM
Removing carbon canister, fuel evap. emissions pdogg Non-Generation Specific Questions 2 09-17-2008 06:58 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel line problem Damian MKIII Supra 1 07-23-2005 10:22 PM
