Old 10-31-2009, 02:38 AM   #1
AlexSchuSupra
AlexSchuSupra's Avatar
AlexSchuSupra is on a distinguished road
Smile 2JZGE Swap....not 2JZ-GTE
Ok so I searched the forum and i didn't find anything on swapping a 2JZGE into an mk3 suppra. I have a N/A 87 Supra and I found a 2JZGE for 500 bucks. I'm not ready to go turbo yet....not enough money so I was wondering what is involved in this swap and is it realistic?
AlexSchuSupra is offline   Reply With Quote
Old 10-31-2009, 11:09 PM   #2
DarkSupra2.5
DarkSupra2.5's Avatar
DarkSupra2.5 is on a distinguished road
Two big things you'll have to deal with during this swap. You'll have to get a 2jz bellhousing for the w58 transmission if that's the trans you have. Then you'll have to do a wiring swap for the 2jz engine control system which isn't easy. I've always wanted to try to retrofitting the 7m engine control system to control a jz engine, but i haven't the time to try it.
This isn't counting w/e little things you'll need like clutch, flywheel, cooling system parts, and misc. sensors you'll need. Have fun with that.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
DarkSupra2.5 is offline   Reply With Quote
2jzge engine, tranny swap onlyfishn MKIV Supra 5 01-29-2010 04:42 AM
1JZ swap or 2JZ swap luneytunes369 MKIII Supra 5 11-14-2008 01:21 PM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
MKIV auto to manual swap?? awd4g63tsi MKIV Supra 0 10-24-2005 08:46 PM
