Old 11-11-2009, 07:27 PM   #1
rpg
rpg is on a distinguished road
Default 1990 7mgte with only 120K miles on auto
so i am having transmission problems especially when i am crusing down the highway.. when i wromp on the gas pedal it hesitates and makes like a jerking sound the rpms barely go up and the mph barely moves. i don't kno if its a highspeed clutch problem or if its a bad sensor the transmission fluid has been recently changed..
rpg is offline   Reply With Quote
Old 11-13-2009, 01:29 PM   #2
MA70-3.0GT
MA70-3.0GT's Avatar
Welcome to the forums. It's hard to diagnose something like this without actually seeing/hearing the car, perhaps you could post a video from a standing start accelerating moderately to say 45mph & then flooring it (going for kickdown)?
Not sure what you mean by a jerking sound either but from the fact you say the rpm's hardly rise I'd suspect a misfire, meaning it's more likely an engine running fault than a gearbox issue. Generally autobox problems seem to fall into one of two categories, slipping/loss of drive (symptoms, revs rise out of proportion to speed & don't drop when the box changes up. like a slipping clutch on a manual basically, or just no drive at all). The other usual autobox fault is jerky/sudden changes which can be caused by sticky valves or dirty fluid.
Like I say it's hard to diagnose without a video, but I doubt you have a gearbox problem from this post.
Cheers, Dan.
is a 1990 auto turbo I6 motor reliable inline6 turbo MKIII Supra 7 07-10-2006 04:05 AM
