ok one day while driving my brakes began to feel a bit soft but would firm up again when pumped, now when car is running the brake petal is very soft and brakes are not very responsive and if i pump the brake hard a few time my engine begind smoking!
1989 toyota supra turbo targa top 7mgte, Five speed left hand drive. |
Loosing brake fluid? Check the hose going from the booster to the intake manifold for oil inside it.
It's time to tear down the master cylinder and inspect it for bad seals and deterioration. http://www.cygnusx1.net/Supra/Librar...Section=BR&P=9 http://www.cygnusx1.net/Supra/Librar...spx?F=4702&P=1 You're going to need to clean out the booster as well once you repair/replace the master cylinder: http://www.cygnusx1.net/Supra/Librar...ection=BR&P=20 http://www.cygnusx1.net/Supra/Librar...spx?F=4703&P=1 Make sure the check valve to the booster isn't sticking due to the contaminants in the vacuum line: http://www.cygnusx1.net/Supra/Librar...spx?F=4703&P=2 (Make sure you put the check valve back on in the same orientation it was in originally!) Fix the exhaust leak. ![]() |
Thanks alot that was some really good info. ill look into it i also found a guy selling a master cylinder and booster for 100 so i may just get that instead and save the time and trouble of tearing down that master cylinder.
87 Turbo Supra rough engine problem | SupraKat | MKIII Supra | 8 | 06-26-2010 05:33 AM |
New supra, computer problem, turbo problem? | mamory | MKIII Supra | 4 | 05-21-2009 04:54 AM |
Dream Offer | Karma_Supra | MKIV Supra | 22 | 10-17-2007 03:04 PM |
87 supra brake lights | ministrytrav | MKIII Supra | 4 | 11-23-2005 08:53 PM |
brake lights problem | MWoz34 | MKIII Supra | 2 | 09-14-2005 03:08 AM |
