Old 11-16-2009, 08:47 PM   #1
2Fast2Furious
2Fast2Furious is on a distinguished road
Default wheel offset
I am purchasing a set of Alloys from ebay
SIZE: 8.0x18" 5x100/114 ET45
I own a Turbo MKIII - the supplier wants to know if my model has the bigger front brakes?
I think my car is 5x114 35to42.
So the bolt plan and diametre are fine. What about the offset?
2Fast2Furious is offline   Reply With Quote
Old 11-16-2009, 09:16 PM   #2
Unless you've upgraded them yourself, no. All models used the same calipers. Hell, even if they were one of the more common upgrades 18" would clear just fine.
Old 11-16-2009, 10:01 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
Bolt pattern PCD 5 x 114.3mm Offset 35mm-38mm Centre Bore 60 mm The larger the offset the more the wheel will sit under the wheel arch.. The stock saw-blade wheels are 37 offset. I did have a set of MK4 5 spoke with 50 and 45 offset not only did they look wrong I found the steering very twitchy. I now run with 18 x 8.5 Front and 18 x 9.5 Rears, offset 35mm. What ever you decide; make sure you have the correct bore or order the correct spigot rings. 60.10mm will fit perfect.
Old 11-16-2009, 10:08 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
The you go Link before and after.
Old 11-16-2009, 10:11 PM   #5
Another term for the center bore adapters is hub centric rings or hub centric adapter rings (may be a North American colloquial term)... and yes, they are important. Also, rims with a smaller center bore than Bill mentioned will not work on the car without machining or.... <gulp> spacers to serve as adapters (not recommended).
Old 11-16-2009, 11:57 PM   #6
2Fast2Furious
Thanks Lads
I'm not going to use spacers.
I will have to keep looking till I find a set I like that come in correct OFFSET
Old 11-17-2009, 02:04 PM   #7
kwnate
SP58GT
Tell them you have larger brakes, in case you do want to upgrade the brakes down the road.
Nate
Old 11-17-2009, 03:38 PM   #8
2Fast2Furious
He replied:
How ever these wheels will not fit your car as the the wheel does not have enough X Factor (The space between the inside of the spokes and where the caliper meets on the front brakes, I have other split size options that would suit your vehice if they are of any interest?
I am looking for a gloss balck set of 18", would like staggered with wider on the back. I like single 5 spoke.
Old 11-18-2009, 01:32 AM   #9
2Fast2Furious
Right I have found a set I like. OFFSET, BORE etc is spot on. Should I go:
8.5x18" Front 9.5x18" Rear
or
8.5x19" Front & Rear
Old 11-18-2009, 07:57 AM   #10
tangsuto
tangsuto is on a distinguished road
I am not entirely sure on all these different specs to match up the correct wheels and the vehicle. I have an 87 Turbo and I find it very hard to find wheels that I both aesthetically like and the specs to match.
I want to get a set of the new Enkei GTC-01's and I found the size with an offset of 35mm and correct bolt pattern however the enkei website lists the wheels at the 75mm bore diameter and not the "ideal" diameter of 60mm as cited above. Will this still work on an 87 supra?
tangsuto is offline   Reply With Quote
MK3 spare wheel fits TT MK4 car? (can a TT take a 16X7 rim) TONY! MKIV Supra 3 03-20-2007 09:10 PM
1987 ga70 wheel offset nightreaper Non-Generation Specific Questions 2 02-12-2007 08:45 AM
19 inch wheel offset on 94 t/t hks94twinturbo Non-Generation Specific Questions 0 11-05-2006 03:23 PM
Wheel Offset and Width for MK3 Dijkstra Non-Generation Specific Questions 1 02-27-2005 07:44 AM
