#11 |
![]() Toyota Racing Development Join Date: Apr 2007
IMHO, electric fans are overrated. They create a pretty hefty drain on the electrical system which the alternator must make up for... The higher the load on the alternator the greater it's resistance and the greater the load on the engine. Personally, if I ever decide to upgrade my cooling further I'll probably add a flex fan and the appropriate fan clutch... move lots of air at idle and at high RPM flattens out to reduce the resistance and thus lessen the load on the engine. If you do go electric make sure the fans you use flow enough air!
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
Replacing Clutch reservoir Hose and fixing rock plate (plastic one) | Grandavi | MKIII Supra | 2 | 09-29-2008 04:49 AM |
metal head gasket price | noa324 | MKIII Supra | 1 | 04-23-2006 03:38 AM |
Supra radiators w/brass tanks? | Benesesso | MKIII Supra | 3 | 03-10-2006 10:26 PM |
Metal to Metal | dcrusupra | MKIII Supra | 7 | 09-30-2005 11:15 PM |
