Old 01-13-2010, 02:49 AM   #191
cvbikeguy
cvbikeguy's Avatar
cvbikeguy is on a distinguished road
Hanging out with the plugs in the gally? What does that mean?
cvbikeguy is offline   Reply With Quote
Old 01-13-2010, 02:50 AM   #192
Make sure the plug galley isn't full of coolant dufus.
Old 01-13-2010, 03:55 AM   #193
cvbikeguy
cvbikeguy's Avatar
lol. i only got one of the studs through the egr valve on accident. didnt notice and proceded to put the nuts on. pinched the valve and the nut. cant get it off. F me
Old 01-13-2010, 04:45 PM   #194
oregonjoe
oregonjoe's Avatar
Default Coolant
Coolant on outside - OK
Coolant on inside - BAD
Check for collant in OIL and in vacumm hoses. Vacumm can suck coolant into engine. If car is running fine it will burn off eventuallly but will run rough till it does.
Pull plugs and crank engine to purge any in cylinders and check plug tips for coolant.
Not sure what you mean on the valve nut thing?
Old 01-14-2010, 02:45 AM   #195
cvbikeguy
cvbikeguy's Avatar
sweeet ok i fixed it. gonna start the car up in a few hours. just wanna wait for the rtv to dry
Old 01-14-2010, 11:56 PM   #196
cvbikeguy
cvbikeguy's Avatar
Smile crossing fingers
ok just kidding. i got pretty sick last night. also i wanted the RTV to sit a little before i started. soooo im gonna start it up pretty soon today.
so i figure i turn it on.
turn it off
check for leaks
turn it on
check timing
then turn it on and off a few times reaching higher rpm each time?
change oil after 500 miles or so?
Old 01-15-2010, 12:45 AM   #197
oregonjoe
oregonjoe's Avatar
Default Start up
Good luck!
Everyone has their own opinion on this.
I started mine, ran for 30 sec to 1 minute then shut off to check for leaks
Then restart and run to check timing avout 5 minutes. Really can't get a good timing check till the engine is fully warmed up and the thermostat opens up at which time the ECM has backed off the idle control motor and engine pulling max vacuum. At this point you listen for vacuum leaks (hissing sound) which will also cause the engine to loop at idel (if ait can hold idle)
Only after the engine will idle smooth after full warm up do I rev anything or drive it.
When thermostat opens up the engine RPM will drop from 1500 to about 1000
Turn off and check OIl to be sure no water is getting in from head job.
NOW is the time to actually drive it. I use short burst to 3000 from dead stop and coast to let engine cool down between busts (30 sec each) Its a fun time because a rebuilt engine will have some pep. The graddluy increase time getting to 3000 in burst with cool down inbetween. I only ran for 5 minutes at atime for first few runs with cool down so cylinders did not get too hot before rings got a chance to seat (thrich is to keep oil from glazing to walls)
Then take it on short drives with lots of dead stop to 4000 as fast as it can. You are trying to load the crank, valves and rings so they get through full travel during bearkin.
Thats how I do it - worked for me several times. Others baby it for 5000 miles. - To each his own.
Old 01-15-2010, 12:52 AM   #198
Me, I'm wasteful after big jobs like this. I run the car up to normal operating temps at idle while searching in a frantic and paranoid manner (frantic is key) for any leaks, sparks, weird green critters chewing on wires and so on.
Then I'll take the car for a short drive, about 5 miles, head home and inspect further.
No leaks? Then I'll go for a 20 mile drive. When I come home I'll look again for signs of trouble and let the car cool. After the car has cooled I replace the oil filter and change the oil.... hope you used cheap oil... And top off the coolant.
For the next few hundred miles (500-600) I'll change the filter one or two more times (not the oil), top the oil off and keep a VERY close eye on coolant and oil levels and watch for signs of contamination.
After five or six hundred miles I'll change oil and filter again and return thereafter to my regular maintenance schedule. I may change the coolant at this point... depends on how clean I think I was and if the cooling system as a filter or not.
Thanks Joe, I keep forgetting he's also breaking everything in. I agree with your methodology for the break in side of things.
Old 01-15-2010, 09:49 AM   #199
cvbikeguy
cvbikeguy's Avatar
So attempt no. 4 has failed. Manifold still leaks in the same spot.
Did I not put enough rtv or something? Also a couple injectors are leaking. They are properly placed and everything.
This car, is cursed
Old 01-15-2010, 04:35 PM   #200
oregonjoe
oregonjoe's Avatar
Default leak
where exactly is it leaking - diagram?
Does the engine start? or is leaking bad while cranking?
Really don't need much RTV at all - just a thin film - so it must be a bad fit, crack, missing bolt, bad nipple fitting, bad or cracked hose?
Lower Ball Joints - Checking here first Grandavi MKIII Supra 3 09-20-2008 04:04 AM
Picking up my 89 tomorrow 8uwav6 Show n Tell 2 03-31-2008 08:08 PM
Checking Thermostat scruffboy Non-Generation Specific Questions 6 03-09-2006 05:49 PM
Supra Noob checking in from Florida PalmCoastMk3 Non-Generation Specific Questions 1 12-23-2005 05:08 PM
Supra Newb Just checking in Razor Non-Generation Specific Questions 1 12-21-2005 04:15 AM
