#201 | |
![]() Quote:
also my dad has informed me that he accidently stepped on my injectors as he was walking around the garage. ![]()
86 MKIII Supra East Bay, CA 7mge rebuild. http://www.toyota-supra.info/forums/...-tomorrow.html MKIII commercial http://www.youtube.com/watch?v=HY9W3...om=PL&index=27 lightening build http://www.toyota-supra.info/forums/...ing-build.html |
#202 |
not quiting yet....
on the bright side im learning a whole lot about cars..... still dont know much so it turns out one a couple of the grommets on the injectors were leaking. the thing is i cant get the factory ones off. they spin but dont like off. im afraid to put too much pressure and break something else. also theres no crack on the intake runner and the hose nipple looks fine. so im buying another gasket and will try again tomorrow hopefully. and tool to get these grommets off? thanks ![]() ![]()
#203 |
just as an update to what i replaced.
spark plugs pretty much all the hoses water pump fan clutch radiator new head machined block rebuild kit
#204 |
![]() Toyota Racing Development Join Date: Apr 2007
Just crack the old grommets with some wire cutter, what doesn't cut usually crakcs anyway and they'll come right off. I HIGHLY recommend replacing all of the gormmets and O-rings.
Good luck with the new gasket... I have no idea why that's causing you so much trouble. ![]()
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#205 | |
![]() Quote:
#206 |
hehe it worked. cool cool. we will see how this goes tomorrow. round no. 5!!!!
#207 |
oops! thanks cre. saved my butt again.
so i got the gaskets in. trying to finish up before it gets late. just broke a connector that my brother soldered. oops. oh well so we should be firing up the car soon. just throwing together the intake.
#208 |
So - are you saying replacing the intake gasket solved the leak?
Yup - the only way to really lean about cars is taking one apart and putting back together. Good luck. |
#209 | |
![]() Quote:
oh hey i like this ![]() makes me appreciate my stock body. just want it slightly lover and stiffer. heard alot of people use HR springs. i dunno though. cause im planning on lightening this car up a bit so id prolly need springs t fit the different weight load no? also need new tires asap. the look bad....
#210 |
lol some guy from up the street came to me asking about his car. :P if only people knew im a plumber... not a mechanic
Thread Tools | |
Display Modes | |
Lower Ball Joints - Checking here first | Grandavi | MKIII Supra | 3 | 09-20-2008 04:04 AM |
Picking up my 89 tomorrow | 8uwav6 | Show n Tell | 2 | 03-31-2008 08:08 PM |
Checking Thermostat | scruffboy | Non-Generation Specific Questions | 6 | 03-09-2006 05:49 PM |
Supra Noob checking in from Florida | PalmCoastMk3 | Non-Generation Specific Questions | 1 | 12-23-2005 05:08 PM |
Supra Newb Just checking in | Razor | Non-Generation Specific Questions | 1 | 12-21-2005 04:15 AM |
