Old 11-26-2009, 02:59 AM   #41
cvbikeguy
cvbikeguy's Avatar
cvbikeguy is on a distinguished road
haha im glad you didnt understand my stupidity. so i was actually trying to take off the hex bolts in the middle of the head.
then after frantic searching i realized these arent the head bolts.................
the build goes on.....
cvbikeguy is offline   Reply With Quote
Old 11-26-2009, 03:56 AM   #42
Ah, well that is good. I don't know why people seem to have so much trouble with those. Good luck with the real head bolts when you do get to them and remember to take them out in the correct order!
Old 11-26-2009, 04:55 AM   #43
cvbikeguy
cvbikeguy's Avatar
theres an order?
Old 11-26-2009, 05:28 AM   #44
Yes, there's an order (for both installation AND removal)... there's an order to the cam bearing caps as well.
Start here and keep reading: http://www.cygnusx1.net/Supra/Librar...ection=EM&P=32
Old 11-28-2009, 05:53 PM   #45
cvbikeguy
cvbikeguy's Avatar
Default blown head gasket?
soooo we got the head off and the gasket actually doesnt look too bad. but then again theres alot of crap in my cylinders tho. pics......
man that TSRM helps alot. thanks. so yea everything looks pretty good. oh well time to continue with the build. timing cover, alternator brackets
Old 11-28-2009, 07:28 PM   #46
cvbikeguy
cvbikeguy's Avatar
Default piston 2&3 are cracked
ok due to further inspection we noticed that the piston heads are actually cracked
it seems as if they were running like this for a while because there arent any pieces of metal in the cylinder, just metallic dust. jusdging by the look of the block and the cylinder head nothing is damaged. we are still unsure but if that was the only problem then we will just get new pistons, gaskets, and ARP head bolts and start with the re-assembly.
Old 11-28-2009, 08:10 PM   #47
Cracked piston... or pistonS (plural)? Either way at this point I would tear the whole thing apart. Metallic sparklies in the oil do not do good things for the bearings, oil pump, turbo... etc., etc....
Have any pics?
Old 11-29-2009, 12:52 AM   #48
cvbikeguy
cvbikeguy's Avatar
pistons, 2 and 3. here are the picsssss
bout to remove the starter.
cracked pistons.... ouch
timing cover crap coming off (sorry if im not too literate with all the car terminology. i honestly know nothing about cars)
cover removed
taking off... whatever that is.
lifted car up to disconnect
so yes i am definitely going with the machine shop. too much metallic dust inside the block. soooo i have everything disconnected and the engine is now ready to be hauled out to a machine shop..... sweeeet
Old 11-29-2009, 01:01 AM   #49
Yeah, that need to go to the shop... that's terrible.
The "whatever that is" would be the block side of the water pump.
Old 11-29-2009, 01:15 AM   #50
cvbikeguy
cvbikeguy's Avatar
haha thanks cre.
Lower Ball Joints - Checking here first Grandavi MKIII Supra 3 09-20-2008 04:04 AM
Picking up my 89 tomorrow 8uwav6 Show n Tell 2 03-31-2008 08:08 PM
Checking Thermostat scruffboy Non-Generation Specific Questions 6 03-09-2006 05:49 PM
Supra Noob checking in from Florida PalmCoastMk3 Non-Generation Specific Questions 1 12-23-2005 05:08 PM
Supra Newb Just checking in Razor Non-Generation Specific Questions 1 12-21-2005 04:15 AM
