Old 12-04-2009, 05:40 PM   #71
MA70-3.0GT
MA70-3.0GT's Avatar
Tell you what then, seeing as you're getting this block all sorted & you've tipped money into it already then how does this sound?
Pick up a complete turbo car that's either been wrapped round a tree etc, or got a rod through it's belly but good blower, hopefully good head & all the electronics & other bits you need to convert to GTE spec?
Then get your man at the shop to drill the oil drain & flush the block as per cre, and instead of buying N/A pistons for whatever oversize the bores are at, just get Turbo ones.
That way you get a good as new (better than new bearing in mind overbore) block & all the kit you need to make a real GTE motor... Plus you'll have a certain amount of other spares from the wreck which you can either swap to your car if better, or sell off to make some of your outlay back.
Old 12-04-2009, 07:57 PM   #72
If going turbo, I would definitely avoid boring the block unless it is absolutely required.
I recommend installing forged pistons and new stock rods (forged would be even better). Definitely install a GTE oil pump; it's a much higher flowing pump and you'll want it when you add oil cooler and turbo.
Later I would install upgraded injectors and swap in GTE electronics and upgraded fuel pump.
Old 12-10-2009, 02:58 PM   #73
cvbikeguy
cvbikeguy's Avatar
cvbikeguy is on a distinguished road
Default paint
Cre got a new avatar!! cool
so the build continues. just as promised my rebuild kit has come in. new pistons, gaskets, water pump and what-not. free 2 day shipping!!! $275
so due to this being my DD and my boss saying im gonna start work again soon, i decided to keep in N/A but going with Cre's advice i wont invest into this motor till i can get a new one and go turbo. after this build is dont ill invest in other things.
soo today im going to the machine shop so i can drop off the pistons and they can test the cylinders and give me my block back! sweeeet. new head still hasnt come back yet. oh and since me and the lady are going to repaint the body eventually...... we got busy
covers look pretty dang good
amazing having a girl that can wrench
cvbikeguy is offline   Reply With Quote
Old 12-10-2009, 06:15 PM   #74
Krem
Originally Posted by cvbikeguy View Post
*sigh* your totally right. seems liek the best way to do this is to wait till im done having the N/A. dont put too much money into the engine and work on other things. then when i feel like having more power i should swap in the gte and have it rebuilt. less head ache. less stress. less money too.
This is what I'm kinda planning myself... I have a N/A that will probably last me another year or two (I hope)... I hope to get my hands on a 7mgte by then and start (if not finish) the rebuild on it, so it's ready to drop in once the 7mge finally goes... I'm just having a hard time finding a 5 spd manual that comes with the 7mgte rather than seperate... but if seperate it has to be... hopefully I can accomodate that before the 7mge goes as well.
Old 12-11-2009, 10:21 PM   #75
cvbikeguy
cvbikeguy's Avatar
Default more paint
prep work
and paint
man feels like my girl is doing most of the work.....
my friend is talking about getting rid of his 1j and going 2j......
hmmmmm
Old 12-11-2009, 11:01 PM   #76
You've got that feeling too eh?
Old 12-11-2009, 11:19 PM   #77
cvbikeguy
cvbikeguy's Avatar
Lightbulb
hahaha man i should have read that before posting.......
Old 12-16-2009, 12:48 AM   #78
cvbikeguy
cvbikeguy's Avatar
block is here. still waiting on the head and Techniques . pics up soon.
Old 12-16-2009, 08:27 PM   #79
cvbikeguy
cvbikeguy's Avatar
Default movin along
man so this build is starting to get more and more intimidating. i just finished the block last night and the head should be in today. starting to get a little cold feet
oh yea, masking an engine is extremely easy and absolutely stress relieving.
finished the coats at 1 am.
now i need to get puddy for the vacuum lines, bolts, and the crank. and im pretty sure im gonna need a butt load of grease for all these moving parts.....
almost done
Old 12-17-2009, 05:11 AM   #80
cvbikeguy
cvbikeguy's Avatar
Talking delivery
head just came in. going to get the block ready tomorrow and throw it in. sweeeet
Lower Ball Joints - Checking here first Grandavi MKIII Supra 3 09-20-2008 04:04 AM
Picking up my 89 tomorrow 8uwav6 Show n Tell 2 03-31-2008 08:08 PM
Checking Thermostat scruffboy Non-Generation Specific Questions 6 03-09-2006 05:49 PM
Supra Noob checking in from Florida PalmCoastMk3 Non-Generation Specific Questions 1 12-23-2005 05:08 PM
Supra Newb Just checking in Razor Non-Generation Specific Questions 1 12-21-2005 04:15 AM
