Old 12-03-2009, 03:50 PM   #1
TripleC
TripleC's Avatar
Default 1j Breaking up around 5500 to 6500 RPM
1987 Supra 1jzgte Swap with R154.
It has been cold for the past few days here in colorado but 22 degrees yesterday and 7 degrees today. I just got the car and wanted to show a buddy a little of the power My 1jzgte has. Well for the past 2 days it has been a little choppy at high RPm but it ran fine about 3 days ago when it was around 45 to 55 degrees. I did here a small pop from the passenger side of the engine (sounded like the turbo's) but i was not under a real boost when it happened and it wasnt to loud but it was detectable. Do you guy's think i have a boost leak, bad spark plugs or should i kind of plan on it missing a little with the temp being as low as it is??
Any help i have only had the car for about a week
Old 12-03-2009, 11:11 PM   #2
Depending on the sound I'd probably start with checking for boost and exhaust leaks.
Fouled spark plugs may perform worse in colder temperatures due to the richer fuel mixture.
I would start with checking those and check for any stored diagnostic codes.
Old 12-04-2009, 02:45 PM   #3
TripleC
TripleC's Avatar
I drove it yesterday and it was just fine once the car and tires warmed up. i think i was mainly hitting the max boost and spinning the tires cause of the cold. anyhow i am sure it is kind of a precursor to what will soon happen so i will keep this in mind when it happens more often.
Old 12-04-2009, 08:29 PM   #4
There is no reason at all that you would hit fuel cut due to just a temperature drop or from spinning the tires.
Old 12-04-2009, 08:55 PM   #5
TripleC
TripleC's Avatar
Well it seems to be ok today! Pulls just fine but i did not go over 6200 RPM when i drove it at lunch time. Do you think it could be the Spark Plugs and an issue with gap??
Old 12-04-2009, 09:24 PM   #6
Heh, if it was a 7M, I'd say you're hitting the rev limiter... but unless you're running 7M electronics...
A gap issue could definitely cause such problems, but it's not something which just happens spontaneously. As I said before, a spark issue is very likely though, so checking for fouling and yes, even checking the gap is definitely at the top of the list.
is there anyone breaking a supra 3L turbo in birmingham johndawn Non-Generation Specific Questions 0 02-21-2006 11:54 PM
