I'm a beginner and want to know what i need to do. - Engine rebuild.
so i bought i a 7mgte engine, all taken a part already, good condition, but im going to buy a rebuild kit for it. it comes with everything besides a metal head gasket and oil something, lifter i think it was.
What do i do first? how much will it cost me? etc.. Everyones advice is good for me since i dont know much about rebuilding an engine. thank you!! |
Well, the first question is are you going to be doing the work yourself?
Your new best friend: http://www.cygnusx1.net/Supra/Library/TSRM/MK3/ I strongly recommend buying a hard copy from Toyota... it is invaluable and MUCH better than what's available from third-party publishers. You should post MKIII specific questions in the MKIII specific group. |
i am doing almost all of it besides that mechanical like honing the block and cleaning everything so it all fits.
Well, go through the manual I linked to and pay close attention. The only major thing wrong with the manual (other than a couple wiring discrepancies) is the head bolt torque. Head bolts should be torqued to 75ft. lbs.
The Engine Mechanical section is probably where you want to start. |
Dont forget about getting the head resurfaced, block decked and retorqe the head studs after a few heat cycles. That is critical aswell.
also when the head is resurfaced, make sure they dont use a belt sander, Trust me. |
| All times are GMT. The time now is 07:18 AM. |
