All I can get out of my '89' 3L Turbo is
124 mph or 200 kmh (sorry the title states 142, I mean 124) there is no tuning - just plain OEM. Surely this is not right. Could it be something to do with UK Spec cars having a restrictor. EDIT: My car is UK Spec and so shouldn't have restrictor maybe some UK members can enlighten me on this matter. I found the following info on http://www.btinternet.com/~netsurf/mr2t/mr2tfaq.html Speed Restrictor: In Japan there is a legal requirement for all cars to have a speed limiter at 180 km/h, which is equivalent to 112mph. Most Turbo owners report a top speed restricted to approximately 5,250 rpm in 5th gear (about 125mph), and is said to be based around cutting the spark to the engine. The speed limiter can be removed, and amongst other companies Intech (see above) will do it for approximately ?180 + VAT, or this can be done as part of a Unichip ECU chip upgrade, which typically costs around ?380 + Fitting. Note: Many owners report that a side effect of having a speed delimiter fitted is that the Power Assisted Steering can become over-light, as the car thinks it is traveling at a lower speed than it actually is. (This is because the speed signal is also sent to the PAS ECU, and is used to judge the amount of steering assistance to be given) Any removal of the speed restrictor may require a subsequent change of speedometer, as it is reported that the needle will hit the bottom of the dial at about 120mph, and some owners have had problems with needles sticking there ! It sounds like it might be fitted with a restrictor. Its a Turbo and speedometer stays around the 125mph mark. It definately is only doing 124/5mph and is not that the speedometer hasn't been changed after the restrictor was taken off as described above. Sure the top end of Golf GTI is 145mph. I know it is much lighter car though. Last edited by 2Fast2Furious; 12-07-2009 at 01:37 PM. |
restrictors, in my experience, usually trigger a reasonable amount over max speed limit.. not nearly double. I've had restrictors/governors trigger about 90-95 mph... I think the highest I had was 100.. You said you're stock, and these cars are 20+ years old... 124 mph in 5th gear doesn't sound too far off for a stock ride..
Very disappointed in that. 124mph.
She is in getting a few things sorted as you will see from my other thread. There is a serious miss on her - like she takes a while to catch up on herself. We'll see if its any different when I get her back. |
There is no known model of MKIII Supra with a limiter governing the maximum speed... that article was about the MR2 and that does have a known limiter (at least the JDM and USDM do).
me knows its about MR2.
it was just information on restrictors that fitted the situation. thanks for info cre, me now knows its got feck all to do with a restictor now. so cre does 124 sound right to you? |
#6 |
Thant's fine. I didn't know if you were just assuming at was an across the board thing for Toyotas or something.
Top speed depends on many factors... I've been up to an over 140MPH (all GPS verified, the stock speedo isn't reliable) in a few different MKIIIs with plenty left in each one. I haven't tried it in a stock turbo MKIII myself, but I know many people have claimed higher top speeds than that. What happens when you reach 124MPH? Just nothing more to give? Fuel cut? What RPM are you reading then? RPM is a wee bit more accurate than RPM if you know your tire size, transmission gearing and differential ratio. What market was your MKIII originally sold in? You have a 7M-GTE in there, correct? Do you by chance have Traction Control in the vehicle? |
