Old 12-09-2009, 02:37 PM   #1
TripleC
TripleC's Avatar
Default Will these Wheels Fit and be close to flush on my MKIII
PATTERN:5X4.50 or 5X114.3
WHEEL SIZE:19X8.5J
OFFSET:30
or
OFFSET: 43
1JZGTE ,R154, Hallman Boost Controller, HKS bov, HKS Mushroom top Air Filter, HKS Front Mount Intercooler, Greedy Turbo Timer, PLX300 AFC, Custom Divorced Y-pipe, Custom Intercooler Pipeing, RS-R Concept Exhaust, Optima Red Top Battery, Strut bar Brembo Rotors, A1 Traction arms, Megan Coilovers, Stern ST 2 wheels rear 265x30 r19 - front 245x35 r19, New Front Lip, 18 x 8 and 18 x 9 MRR HR2 with whatever for Drift treads
2 additional C12A turbo's(Extra)
Old 12-10-2009, 01:54 AM   #2
suprakillz
suprakillz's Avatar
suprakillz is on a distinguished road
they are the right bolt pattern, the size tho i'm not too sure about.. you should check out www.tirerack.com. there you can find out how big and what offset will fit on your car.. i don't think that 19s are too big tho.
suprakillz is offline   Reply With Quote
Old 12-10-2009, 01:58 AM   #3
supranutz
supranutz is on a distinguished road
i run a tire shop so i speak from experience id run away from anything 19"s they are way too expensive because they arent common enough and if your in a jam and need a tire you likely wont find one in stock possible could end up on back order
supranutz is offline   Reply With Quote
Old 12-10-2009, 02:05 AM   #4
Just my thoughts on the matter: I agree I wouldn't run higher than 18's and I wouldn't want those on anything which sees a lot of use. I've got 17's and they're comfortable enough, but downtown I sure do feel the crap roads. I've worked on a MKIII with the same springs as my car (different dampers though, similar rates though AFAIK) and that ride was rough.
