Old 12-11-2009, 01:39 AM   #1
toyotarunner1992
toyotarunner1992 is on a distinguished road
Default oil drain cap?
I am trying to change the oil in my 87 NA supra and i find not a stud but some rubber gormmet thing with a wing nut on it. when i unscrew the wing nut as far as i can, it jsut starts to twist the stud around in the rubber grommet. WTF... changing oil should be easy i thought... any help would be great... thanks.
toyotarunner1992 is offline   Reply With Quote
Old 12-11-2009, 01:48 AM   #2
916MKIIIx2
Hmm? it should just be a bolt and a composite rasin 0 ring on the oil pan plug... as far as I know, if you had a picture that would help.
Old 12-11-2009, 03:39 AM   #3
So someone installed a drain cock?
Not uncommon, but they do like to clog if the oiling system has sludged up at all.
Or, do you mean an expansion plug?
Where does it all come from???
Old 12-11-2009, 06:28 AM   #4
toyotarunner1992
it looks more like the last picture... there isnt a drain dock because i opened it all the way and it just dribbled out. i tried to pull the whole thing out but i am baffled as to why it was like that and HOW TO GET IT OUT... i want to remove it quickly...and ferosiously throw it at a wall... it took 3 hours to drain all the oil... and then it would not go back in... it is the mosts USELESS thing for cars ever invented.
Old 12-11-2009, 06:42 AM   #5
That's not really for cars... it's used to block off pipes. I've seen them under the hood once or twice but I dismissed those encounters as more DIY brilliance.
Careful when removing it, or reinserting the screw... the nut on the opposite side could get pushed out into the oil pan. The problem you're probably going to have is that if it is a plug such as those in the second picture the rubber has probably swelled and been cut into by the pan creating a very thick and tough grommet. I would place a very large fender washer on the screw, reinstall the screw enough so you're positive it's securely threaded into the nut on the back side and then try to get a small pry bar in there. You could also try using a hot air gun to heat the rubber and pan to make the job easier, but I wouldn't try a torch.
Can you post a picture?
Old 12-11-2009, 08:01 AM   #6
916MKIIIx2
Make sure when you change your oil and get a new, proper screw plug you always change the composite gasket that seals it everytime you change the oil ^^
Old 12-11-2009, 11:03 PM   #7
Also don't over tighten the plug. there's a thin spot where the flange overlaps that can get crushed creating a dimple which will leak.
How to change your oil SupraSaver87 Supra FAQ 14 04-14-2010 03:49 AM
need info on tranny drain bolt flight doc89 MKIII Supra 2 05-11-2006 05:10 PM
R154 drain plug? Suprapowaz! MKIII Supra 2 03-17-2006 06:16 AM
water leaking from A/C inside car Ron90Turbo MKIII Supra 2 09-12-2005 04:31 AM
Headlight battery drain Steve Curtiss MKIII Supra 0 02-10-2005 07:00 PM
