Old 12-21-2009, 03:49 AM   #11
bryanf89
I strongly agree because the air box is still using the air from under the hood where as the cold air intake is able a much greater volume of air at once with restriction and many put a heat shield near the shield along with engine exhaust insultion. Also, if it wasnt effective then why would almost mechanic recommemd it?
Old 12-21-2009, 03:59 AM   #12
Wow... decaf man, decaf. I'm not entirely sure I understood that. Mechanics recommend what?
Even with an insulated exhaust the engine bay temps will always be higher than outside. The block, transmission, clutch, A/C compressor, P/S pump all release heat into it.
Old 12-21-2009, 04:29 AM   #13
bryanf89
Lmao im lik twitch from south park...no honestly i completly messed that up but yes your right i guess your best bet is to ride without a hood lol
Wide body kit question? JPDsupra MKIV Supra 1 04-22-2007 01:10 PM
Jdm Throttle Body Luvs2slide MKIII Supra 1 07-24-2006 07:15 AM
throttle body 87supraguy MKIII Supra 0 02-17-2006 02:40 AM
throttle body boogum7 MKIII Supra 5 12-21-2005 03:01 PM
