Old 12-14-2009, 02:52 AM   #1
JaegerUtah
JaegerUtah is on a distinguished road
Post smoking / overheat
i have a 89 n/a supra fix the head on it over a year ago. two days ago was seeing a lot of white smoke out the back, under the hood and under the car. i have found and area on the passenger side next to the down pipe. of where it may be. but the strange thing is tonight i started it not really any smoke until 10 mins of running and a puddle of antifreeze under the car right near the cat. so if anyone can help me with this like asap it would mean alot to me thank u i will be back on Dec 14 2009
JaegerUtah is offline   Reply With Quote
Old 12-14-2009, 07:41 AM   #2
Have you been making sure to keep the coolant system full?
There are only a couple places where it is likely to be coming from if it's pouring down the exhaust and they're all right in front of the fire wall on the passenger side. On the up side, they're not all terrible to get to, on the down side, there is one 90? hose behind the head which is miserable. Hopefully it'll be one of the heater hoses, a crack in the heater control valve or the rubber plug on the metal pipe which peaks out from behind the engine. The Head gasket is a possibility, but I think a hose is more likely.
If you can't spot the source of the leak by hand or feel then go get a pressure tester and have at it.
http://www.cygnusx1.net/Supra/Librar...spx?F=1603&P=1
http://www.cygnusx1.net/Supra/Librar...spx?F=8716&P=1
Old 12-14-2009, 04:40 PM   #3
Cyto
Cyto's Avatar
Cyto is on a distinguished road
I agree, the right cap ruptured on mine. It was doing the exact same thing... EXCEPT, I accidentally blew the HG and had to spend over 1 grand fixing it... and it still ruined some stuff that I haven't gotten around to fixing. So check the heater hoses and stuff. It'll save you time and money!!
Proud owner of a 1988 Toyota Supra Turbo, 105k Miles, and great condition.
I might have to sell it to help pay for school so here's the link.
http://www.toyota-supra.info/forums/...html#post72357
Cyto is offline   Reply With Quote
Strange exhaust smell --1990 7MGTE smoking the greens?!?!?! 916MKIIIx2 MKIII Supra 1 12-11-2009 09:26 PM
mk IV coolent overheat shinobi MKIV Supra 11 12-27-2007 04:16 PM
Smoking Tail lights trd-drifting Exterior , Interior, and Detailing 5 11-06-2006 05:22 AM
Smoking transmission Isphius MKIII Supra 5 08-31-2006 04:52 PM
1JZ-GTE 2.5 TT Overheat megawatts Non-Generation Specific Questions 0 08-28-2006 09:13 PM
