Old 12-14-2009, 08:39 PM   #1
Krem
Default Symptom of Bad Fan Clutch?
so as I was taking my car to get repaired last week, I was sitting at a red light waiting for the left arrow to turn green and watched my temp gauge go from middle to prob 85-90% (just below the red hash for hot temp). This was as high as it got as when the light turned green and I accelerated, a quarter of a block later, the temp dropped back to dead middle of the guage (fell in a matter of seconds, as if I shut the car off)
After getting the car back, I was told I need to address the fan clutch as it's going bad. Sat. night as I was omw to pickup gf from work, again I was waiting at a (different) left arrow... waiting for the green, I see the temp spike in the same manner as before... sure enough, just like before, once I started driving away, the temp dropped back down.
Could this be the fan clutch failing and no air circulation past the radiator? causing it to cool down once I drive and push air across the radiator again? or does this sound like it could be something else specific?
Old 12-15-2009, 02:56 AM   #2
A few things will cause this... A restricted flow in the radiator (especially if you don't have the fan cowl in place) is very common. A bad fan clutch is equally possible, rebuild it and see.
Old 12-15-2009, 09:01 PM   #3
Krem
well, I seriously doubt the radiator is the problem, else I should get my money back as it was rodded out and rebuilt last week.. but the guy did say my fan clutch needed to be replaced and was "going". Planning on replacing the fan clutch and installing the top and bottom shrouds this weekend... so hopefully that'll fix it... parking the car to play it safe but still driving it to get dinner or make corner store runs at 10pm, etc... if I see it happen again before I can make repairs, would reving or turning the car off and back on help initialize the fan clutch? or is it one of those "never can tell, if it's broke, nothin will help" kinda things?
Old 12-15-2009, 11:56 PM   #4
The fan clutch is a hydrostatic device (I believe that's the correct term)... nothing to initialize, just a maze filled with oil.
Old 12-16-2009, 12:27 AM   #5
Krem
hmmmm, well that sux... sounds like the only way I'll be able to re-engage the fan if it's clutch fails is to manually spin it and hope the clutch catches and spins the fan with the crank... well, she won't see much road time in the next few days anyways... but you mentioned oil? is this something sealed within the clutch to lube the moving components? or is this oil something I'll encounter and need to prep for in my fan clutch replacement this weekend?
Old 12-16-2009, 12:42 AM   #6
Manually spin what??? There's nothing to 'catch'. You really should Google fan clutch and read up on how they work.
Clutch kit for a 1993 JDM Toyota Supra SpRuCe Non-Generation Specific Questions 0 04-13-2009 10:20 PM
HElp with sports clutch!! whitequasimodo MKIII Supra 3 05-07-2008 11:06 PM
