Old 12-15-2009, 12:48 PM   #1
BillW
BillW is on a distinguished road
Default Wind noise near driver mirror
I have this annoying wind noise inside my 89, when I have the window rolled up and go past 40 mph. It's coming from near the driver side mirror. I slipped a piece of paper in and out, between the weather stripping and the door/glass, and feel a little less resistance pulling the paper out near the noisy area. I glued a 5" long piece of rubber cut from bicycle tube, along the weather stripping near the sound, to try to tighten up that area, but no change in the sound.
Does anyone have any ideas how to trouble shoot and reduce wind noise? I know there will always be some wind noise at speed, but the sound from near the mirror is much louder than the rest.
Anyone else experience this wind noise from near the mirror with the window rolled up? Is it just the aerodynamics of the car? Thanks.
BillW is offline   Reply With Quote
Old 12-15-2009, 07:41 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
Not an unusual problem, the rubber seal (arrowed in the photo) becomes hard due to age. I've had this problem on a few supra`s ; remove the wing mirror and using two pieces of wood and a G clamp squeeze the seal together. On the inside of the seal there is a metal plate, don’t close the seal gap too small or the window could jam. Just nip it up a bit at a time.
Old 12-16-2009, 02:12 PM   #3
on my supra there was a small chip out of the plastic piece (triangle plastic attaching mirror to the door)
i just said f***it and put a new mirror on
Old 12-17-2009, 05:09 AM   #4
BillW
Smile
Thanks so much for the advise. It is so nice not to hear that wind noise.
I could not see how to take the mirror off, so I cheated, left the mirror on, and used channel locks with some small pieces of wood to squeeze shut the area that you had marked with the arrow. Did the trick.
If not for your diagram and instruction, I would be still gluing bits of bicycle tube to the weatherstripping trying to stop the noise. Thanks.
Tags
noise, wind
engine makes knocking noise.. 88WhiteMKIII MKIII Supra 4 06-10-2009 09:09 PM
Noise From The Trunk Help krupt_01 MKIV Supra 1 02-19-2009 10:47 AM
Terrible noise from the Drivebelt area 94TT MKIV Supra 2 12-04-2006 12:29 PM
Help with wierd noise SupraSaver87 Non-Generation Specific Questions 5 07-06-2006 12:10 AM
help on knock knock noise Guest MKII Supra 3 05-31-2005 07:41 PM
