Old 12-17-2009, 02:58 AM   #1
brad88supra
brad88supra's Avatar
brad88supra is on a distinguished road
Default venom 400
has any body tried the venom 400 module on your car.
1988 N/A Supra, 5 speed, Targa top, Tems
brad88supra is offline   Reply With Quote
Old 12-17-2009, 02:35 PM   #2
http://www.horsepowerfreaks.com/perf...ment_Piggyback
is there any downside??
it sounds kool
Old 12-17-2009, 08:40 PM   #3
brad88supra
http://www.directautomotiveproducts.com/vfmaey.html
its 100 dollars cheaper here, you can get the turbo one too but mines na, it sounds pretty cool, I read some consumer reviews, all of them said they were happy with it
Old 12-18-2009, 03:24 PM   #4
kwnate
SP58GT
It's even cheaper to not buy it at all. Buy a nice suspension setup and some good looking wheels instead. If you want to go fast, swap in a turbo motor and turn up the boost. I've never heard of anyone buying a venom piggyback.
What are your goals?
Nate
Old 12-18-2009, 08:06 PM   #5
Definitely snake oil.
As far as I can tell from some very quick research this system makes adjustments to the ECU's airflow signal rather blindly. The system gets information from the throttle position sensor and the air flow meter and causes changes in the fueling of the vehicle by modifying the air flow signal received by the ECU (some times a piggyback will alter the TPS signal as well, but it is uncommon and never the sole means of modifying the ECU's fueling and timing). The change in reported air flow causes changes in fueling and timing. The problem is that this is a completely blind change on the part of the Venom unit. It has no idea what air to fuel ratio its changes are causing nor does it know what changes are ideal for your specific vehicle. Sure there are trends in a given series of engine which can be used as a guideline for base changes, but every vehicle is quite different and those differences are amplified with age.
This "piggyback" falls between the "AMAZING SuperChip! +85HP instantly! Only ONE Wire!" and the original SAFC. I'm sure (I hope) some time was spent to find a basic map for changes but they're not going to be tailored for your vehicle. At least with the SAFC you have the control over the changes and you can tune specifically for your vehicle.
One reviewer may have it just right: "HPF was awesome in their customer service/shipping. However, the Venom ECU is a scam. All this system does is make your engine think it's at full throttle when it's not. Instead of spending $300, just push the gas pedal all the way to the floor. You get 0 top end performance gains from this product. Research items BEFORE you buy them."
Your money would be much better spent on a MAFT Gen II and a GM MAF.
Old 12-19-2009, 09:32 PM   #6
well when u say it like that
POS...
Old 12-19-2009, 09:35 PM   #7
Yeah, you're better off buying an original SAFC or a SAFC II used and paying a shop to tune it.
Venom 550cc injectors? ravenmaster MKIII Supra 5 03-19-2008 10:24 AM
Venom 400??? Worth it? ravenmaster MKIII Supra 3 10-08-2006 08:26 AM
