Old 12-19-2009, 12:03 PM   #1
nosuprayou
nosuprayou is on a distinguished road
Default check engine light & bulb light, what?
alright, call me stupid but lately when i turn the key to the 'accessory' position my check engine light turns on and the light for my bulbs go on. when i start it both lights turn off. im pretty confused right now. if there was a reason to check my engine wouldnt the check engine light stay on? also, i checked all my bulbs and they all work. anyone know weather im just trippin over nothin or if somethings up?
nosuprayou is offline   Reply With Quote
Old 12-19-2009, 08:10 PM   #2
The check engine light should always be on if the ignition is in the "ON" position but the car is not running. It's a diagnostic... so you know the CEL is functional. Non of the dash lights should be on with the key in the "Acc" position.
Now, even though you do not have the light when the car is running it doesn't mean there are no fault or diagnostic error codes stored in the ECU. Only the most critical of errors will cause the light to remain lit.
Here's how to check diagnostic codes:
http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
Old 12-19-2009, 09:15 PM   #3
nosuprayou
my bad. i meant that the light turns on in the 'on' position. thanks for the link. ill find me a paper clip and try it out after work tonight. thanks man. ive been a little worried and confused about it for the past few days. i had my car sitting for a few days to change out the radiator and afterwars coulnt remember if that always happened.
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
check engine light Clorox9 Non-Generation Specific Questions 1 05-08-2009 06:57 PM
Check Engine Light Johnny boy 82 MKIII Supra 2 06-09-2006 09:41 PM
check engine light ironcobra2002 MKIII Supra 4 11-05-2005 04:07 AM
