Old 12-22-2009, 08:13 PM   #11
Do you know how to test for voltage drop across a line? You place one test lead at each end of the wire (the wire needs to be connected so there is voltage to read), place the negative lead on the side closest to the + terminal in the circuit then place the negative on the other end. The voltage you see reported will be the total drop across the wire. More than a couple hundred mV and the wire should be replaced.
When testing across a larger circuit it is sometimes easier to test the whole thing and then slowly close in until you've found the individual point of failure. So in this case you'd place the negative probe on the battery's + terminal. Then you'd place the positive probe at the harness' +B connector resulting in a reading of a drop of about 10v. Now you move back along the circuit to the next junction and test. If the voltage drop is still present you move along to the the next junction closer to the battery. If it isn't then you test the voltage drop across the wire at the ECU harness and that first junction.
Old 12-23-2009, 02:15 AM   #12
discord
discord is on a distinguished road
now the car is back firing thru the intake and exhaust pipes are getting warm...I havent check any voltages yet, but the back firing thing has been the most activity since it was installed? good thing?
1991 supra targa turbo
full rebuild, garrett turbo, chrome header, custom made adjustable wastegate and matching bov, elec fan, hks evc pro, greddy turbo timer, hks 2.0mm hg, arp head bolts, arp rod bolts, 2.5" intercooler and piping, lexus ls400 MAF. AC, power steering, and clutch fan deleted.
discord is offline   Reply With Quote
Old 12-23-2009, 05:18 AM   #13
The back firing means the mechanical timing is a mile off. Realign everything to 0? then look into the voltage issues.
Old 12-23-2009, 05:30 AM   #14
discord
ok, will do, and i'll get back. thanks much for your help
Old 12-23-2009, 05:34 AM   #15
discord
oh ya and to get the timing right i'll need to know which wire go where on the cas. I had to get a new connector because the wire on mine were deteriorated and came out of the connector. I can only guess where the go. I had a guy bring over another harness so I could tell but he will not answer my calls now. the wires before the connector on the stock haarness are a different color then the ones after so I cant match the colors? anyone have a picture of theirs? thanks!
Old 12-23-2009, 08:47 AM   #16
What? The CPS harness perhaps? The wires on the side of the CPS are not matched to the harness.... at least I've yet to see one that matches. I can get the colors from my '88, but they may be different getting the info from someone with an '89 or newer would probably be best.
If you're not talking about the CPS harness (has 4 wires) then post a pic.
Old 12-26-2009, 10:03 PM   #17
discord
I got them right now, looked at a friends harness. got new coil packs now and have a good strong spark. still just backfires into the intake. all voltages check out. ignition switch is good. refueled gas tank, timing is perfect, no dice. still occasionally backfires into the intake.
Old 12-26-2009, 10:38 PM   #18
Backfiring into the intake indicates that the intake valves are opening too soon after ignition.... I know of no other way for this to happen than the mechanical timing being off; I am not talking about the spark advance if that is what you are referring to.
Old 12-26-2009, 11:19 PM   #19
discord
what should I do to fix?
Old 12-26-2009, 11:31 PM   #20
Bill UK covered it well in pictoral form here: http://www.toyota-supra.info/forums/...on-sensor.html Those three items set the mechanical timing, then you tighten the timing belt tensioner pulley (do NOT over torque it!!!), then you set the ignition timing with the timing light.
Stalling at start up Green7mgte MKIII Supra 4 12-15-2009 06:31 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
