Old 12-21-2009, 12:22 AM   #1
discord
discord is on a distinguished road
Default no start after rebuild
ok I have been on this forum for months now. I just finally registered because this is an issue I have not found a suitable solution to. the car was givin to me by my good friend of 20 years. its a 91 turbo. the car lost a bearing and was parked 2 years before I started on it. I pulled the motor and got a low mileage long block, tore it down and completely rebuilt it with good stuff, added a header and garrett t04e turbo and hks downpipe, hks evc pro, hks 2mm hg, arp head bolts, arp rod bolts, high performance piston rings, custom made wastegate and matching bov, and greddy turbo timer. power steering, ac, and clutch fan deleted. everything is installed correctly. I used vacuum diagrams from this forum and also the tsrm.
the car will not start. triple checked timing, rewired cas, and checked for fuel pressure. cranks but will not start. also tried resetting the security system by opening all doors, hood, liftgate, and lock/unlocking all doors. no dice. check voltage at coil pack, igniter, and found them good. has new plugs in it as well. have gone threw every check that I could find on this site and others without success. there is also no spark which obviously why it wont start (im guessing). so there is where I need to start. but how?
discord is offline   Reply With Quote
Old 12-21-2009, 03:44 AM   #2
Well, let's start simple. Does the car turn over at all when you turn the key? Any diagnostic codes stored? Have you checked to ensure the CPS isn't installed 180? off? Have you tested for power that the ECU (Batt, B+ and B1+)?
Old 12-21-2009, 05:56 AM   #3
discord
yes double and triple checked the cps. showing 12v at b1 and no + voltages on bat and b2. the plug is removed from ecu while checking
1991 supra targa turbo
full rebuild, garrett turbo, chrome header, custom made adjustable wastegate and matching bov, elec fan, hks evc pro, greddy turbo timer, hks 2.0mm hg, arp head bolts, arp rod bolts, 2.5" intercooler and piping, lexus ls400 MAF. AC, power steering, and clutch fan deleted.
Old 12-21-2009, 06:28 AM   #4
discord
oh ya and yes, cranks but does not turn over. thanks
Old 12-22-2009, 02:55 AM   #5
discord
anyone else have any clues??
Old 12-22-2009, 03:17 AM   #6
Uh, yeah:
Unless I misread or you mistyped the ECU isn't getting power at two essential inputs.
Old 12-22-2009, 05:39 AM   #7
discord
yes obviously, was hoping for a place toi start on this
Old 12-22-2009, 07:22 AM   #8
Ah, my apologies. As +B and +B1 are both sourced from the Main EFI relay and the Circuit opening relay I would check the harness in between. I am quite surprised that you have power to one and not the other.
Batt gets its power from the 15A EFI relay. If you are getting power to one of the +B lines though this fuse is unlikely to be the cause of the problem and again, you are most likely looking as a wiring problem.
All three should have power whether the harness is plugged in or not, so long as the ignition switch is in the "ON" position. Have you perhaps tested the ignition switch?
Have you inspected your wire harness since reinstalling the engine?
Here is the wiring diagram for the ECU:
http://www.cygnusx1.net/Supra/Librar...px?S=Main&P=46
Stalling at start up Green7mgte MKIII Supra 4 12-15-2009 06:31 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
