Old 12-09-2009, 11:14 PM   #1
supraluver4life
supraluver4life is on a distinguished road
Default oops i broke the headlight help
ok so... where to begin... so i was sitting out side smoking and went and sat on my car and i heard a snapping noise right when i sat down on it. i broke this thing on the headlight that fucked everything up. its a little clip thing on the back of the headlight that pivots. it snapped. so now when i go to put up the headlights the left one goes up and the right one doesnt it gets jammed against the front lip thingy and when i hit the corner next to the clip that broke it pops up and sits at a weird angle. i was wondering a good way to fix this because its bugging the shit outta me. everytime i wanna put my headlights up i have to get out and hit it hard. so i wanna know how to remove the headlight from the pivot points that are attached to a support of somekind
Cusco front, Tein Rear coilovers
Massive DDP, 3'' custom catless exhaust, Tsudo muffler 4.5'' outlet, Apexi cold air intake, Act stage 3 clutch, ct26 turbo (stock)- 10psi
+300rwhp
"Not driving a car because its too nice, is like not fucking your gf so shes still tight for the next guy"
supraluver4life is offline   Reply With Quote
Old 12-10-2009, 02:21 AM   #2
Could you post some pictures of the broken part please?
Old 12-12-2009, 11:49 AM   #3
MA70-3.0GT
MA70-3.0GT's Avatar
Wow, I just looked in the tsrm & it's pretty useless as far as how to replace/fix the headlamp assembly goes! Here's the single page they devoted to the headlights anyway... http://www.cygnusx1.net/Supra/Librar...Section=BO&P=4
From the sound of things you broke the hinge (visible in fourth pic.) and most likely need to replace the assembly. If you still have the bit that broke off there's a chance you could fix it with epoxy or similar & it might be worth a shot if you can't find a lamp assembly for the right money. I guess if you're really hard-up (or as stingy as me!) you could even make a replacement hinge out of fibreglass if need be...
Old 12-12-2009, 07:23 PM   #4
Yeah, and unfortunately the Toyota collision repair manual for the MKIII doesn't cover this subject. Still, pics would help.... I suspect supraluver4life is going to need to replace the assembly.
Old 12-13-2009, 02:57 AM   #5
Busted Knuckles
Busted Knuckles's Avatar
I just happen to have the ones out of a '87 parts car, left and right side complete assemblies. Send me a private message if interested.
Old 12-16-2009, 12:14 AM   #6
supraluver4life
thank you so much for the help everyone. um yes it is the hinge peice (the furthest right peice that looks like a donut thing in the fourth picture on the link you posted cre) and when you say i have to replace the entire assembly what exact assembly are you refering to. the entire headlight housing???
+300rwhp
Old 12-16-2009, 12:34 AM   #7
Donut thing? The motor's gearbox?
Old 12-17-2009, 02:30 PM   #8
if you need some pics i got my left headlight in pieces...
Old 12-18-2009, 01:20 AM   #9
supraluver4life
pics would be great thanx
+300rwhp
Old 12-21-2009, 01:51 PM   #10
maby this will help u find the part...
only thing not included is the actual light...
Tags
broken, damn, fix, headlight
1985 Toyota Supra Headlight Switch t4yl0r10 Shops & Part Reviews 0 01-15-2009 04:39 PM
MKIII Headlight Problem Supra275 Non-Generation Specific Questions 4 09-05-2008 09:06 PM
Headlight Ground-Wire Issues (YAY!) panda-supra MKII Supra 5 09-14-2006 04:01 AM
my 86 broke pittsupra MKII Supra 2 06-05-2006 11:42 AM
1983 Headlight Motor scorpmatt MKII Supra 3 12-07-2005 02:36 AM
