Old 12-29-2009, 09:24 PM   #1
carl johansson
carl johansson is on a distinguished road
Default hazard switch? where is it?
Ok guys,
took an 88 down to bones and built it back up as a lemons racer, but now i have an electrical issue. the tailights and brake lights do not work - traced to the flasher switch being unplugged. We need em because it is a 24 hour endurance race, on an unlit track!
Unfortunately I cannot remember where the flasher switch was supposed to be located - and if i cut that portion of the dash away.
On top of that. right now I am 850 miles away from the car. so can anyone tell me where the flasher switch is located on these puppies?
and anyone have a spare they are not using?
Carl Johansson
carl johansson is offline   Reply With Quote
Old 12-29-2009, 09:56 PM   #2
Krem
sounds like you're ready for the lemon circuit to me.... but in the off hand you're trying to build a lemans rather than a lemon, you can find the caution switch to the right of the stearing column, left of the climate control cluster.
couldn't resist the joke... probably easier to make a lemans outta the mk3 than a lemon anyways.. good luck, wish I could help more than my sarcasm..
Old 12-29-2009, 09:56 PM   #3
reydio
reydio is on a distinguished road
Originally Posted by carl johansson View Post
Ok guys,
Carl Johansson
Emergency Flasher Switch is beside the Climate Control Switch(on the left side). I'm sure someone close to you will have a spare.
reydio is offline   Reply With Quote
Old 12-29-2009, 11:21 PM   #4
carl johansson
Thanks guys, i'm guessing i CUT THAT OUT IN THE LIGHTENING PHASE = BET i THREW IT AWAY STILL IN THE PANEL, i'LL HAVE TO FIND A SPARE SOMEWHERE! OOPS forgive caps
Old 12-30-2009, 03:01 AM   #5
The hazard switch ONLY interrupts the turn signals... if you're missing brakes, headlights, taillights, etc, something else is screwed up.
As for the hazard switch, since this isn't a street car I'd just wire around it. http://www.cygnusx1.net/Supra/Librar...x?S=Main&P=070
Power window switch 87 Supra BestSupra87 Non-Generation Specific Questions 0 11-07-2009 06:53 PM
Ign Switch Signal for Elec. Fans mkiiisupra MKIII Supra 2 03-13-2009 05:00 PM
oil pressure switch ma70guy MKIII Supra 3 12-14-2007 04:55 AM
Faulty Headlight Switch... please help! MusicNazi525 MKIII Supra 4 10-30-2005 12:31 AM
