I broke one of my lug nut stud moment ago while replacing my brakes.
I did not fallow the proper SOP and temp bolt my roter down so i had wiggle in it. couldent get enough clearance to put my caliper back into place so i started smacking the bottom part of my roter with a hammer.. (so i have anger issues. wanna fight about it..) <- just playing. i really am terribly mad at myself for making such a hairbrained mistake. but i broke off one of my lug nut studs so now what do i do? replace the roter but were do i get the threads at? what are they even called. any thaughts on my problem. im sure im not the first to break a stud so there must be a replacement option available. feel free to laugh at this, humor always lightens the mood and my mood is currently red faced and steaming.
![]() 92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : Last edited by Green7mgte; 01-05-2010 at 04:06 AM. |
So you just stripped or otherwise mangled the threads on the lug? No biggie, a replacement's around $3. Just tap the old one out (they come through from behind), slide the new one in and put some washers on or a 1" segment of pipe on the outside, thread the lug nut on and tighten up to about 70 ft lbs., back it off and then repeat. After you reinstall, retorque the lugs after the first couple drives.
I believe you're after part number: 90942-02049 MSRP $3.20 ![]() You didn't actually BREAK the lug, did you? If so you need to inspect other components for damage such as warping... takes a lot of torque to break one even if it's under an uneven load.
I belive I whacked the stud back through the hole. so hopefully i dident damage the hub behind it.
so i just need to get it out. ill replace it anyhow to be on the safe side..
![]() 92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : Last edited by Green7mgte; 01-05-2010 at 07:24 PM. |
There's not a whole lot to damage back there from just knocking a lug into it. Was this the front or the rear?
Well, I suppose in the rear there are the E-brake components to worry about... the front is a simple affair: http://www.cygnusx1.net/Supra/Librar...spx?F=4303&P=1
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() Last edited by cre; 01-05-2010 at 03:55 AM. |
yea its just the front. I felt like such a heel.. and as soon as it went through a voice in my head said.. "and this is the part were you break it"
oh maybe you could shed some light on this matter. my caliper dosent want to come off. the bottem bolt is removed but its very sticky and tight. for the life of me I cant push it off the top. to fix a broken wheel stud preform the fallowing. Remove the caliper, breakpads and caliper torque plate Remove your rotor and Bang out existing damaged wheel stud Insert new wheel stud and hit with an anti seize place stock lug nut on new wheel stud and tighten -NOTE- tighten only till the back of the stud shoulder is touching the back of the hub, do not over tighten.
![]() 92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : Last edited by Green7mgte; 01-05-2010 at 04:18 AM. |
#6 |
AEM EMS
You guys must have different brake/hub setup to the UK Supra, I’m sure I needed to removed the hub to knock the wheel stud completely through.
Two Issues: Front Brakes and Sporadic Vibration | Chambers | MKIII Supra | 0 | 11-03-2007 04:15 PM |
Front Brakes | zuni | MKIII Supra | 8 | 06-21-2007 05:09 PM |
Brakes 5M Vs. 7MGTE | panda-supra | MKII Supra | 3 | 03-22-2006 09:07 AM |
Should I STILL change head gasket?? | lifesnotfair | MKIII Supra | 7 | 01-13-2006 01:08 AM |
Brakes acting up | maksimus54 | Non-Generation Specific Questions | 4 | 07-06-2005 11:47 PM |
