Old 01-13-2010, 04:09 AM   #1
916MKIIIx2
916MKIIIx2 is on a distinguished road
Default Blew a coolent hose?!?!
Well, I know I blew a coolant hose somewhere behind the engine above the tranny on my 7mgte a/t, I also know I need several other coolant hoses. So what I could use is some sites with good complete sets of coolent hose's. I already have a site for vacuum hose's and such just cant find one for the water coolant hoses. Also can't find too many good diagrams for the hoses in the back of the engine there where the hose blew...
916MKIIIx2 is offline   Reply With Quote
Old 01-13-2010, 04:57 AM   #2
Green7mgte
Supra Forum Moderator
http://www.toyota-supra.info/forums/...-hose-kit.html <- me asking the same question
same thing happened to me. Can't buy a whole coolant hose kit.
I know which hose you blew !!! same one I did that i could not locate ! have fun with that one buddy.
http://www.toyota-supra.info/forums/...ater-core.html <- me with blown hose
http://www.toyota-supra.info/forums/...-0l-supra.html <-- probably one of these.
go rent (or buy like i did) a rad pressure tester $80 form harbor freight or 110+ from autozone (deposit but you get that back)
lastly just purchase a couple pack of different size hoses and clamps + zip ties. 3/4 to 5/8th about 5 bucks each for about 3ft of hose. comes in handy!
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 01-14-2010, 11:07 PM   #3
916MKIIIx2
Anyone got the toyota dealership numbers for the pre-bent water coolant hoses in the back of the 7MGTE? Seems all the the hoses back there had gotten eater up from an old oil leak I fixed a few months ago...
Here are the pre-bent aftermarket ACDelco brand numbers I found for people looking for pre-bent hoses, as opposed to cutting straight hose to length...
ACDELCO Part # 14207S {5/8" x 4 29/32" #88907204}
HOSE,MOLDED CUT TO FIT; PIPE TO THERM
ACDELCO Part # 14002S {3/8" x 9 19/32" #88907003}
HOSE,MOLDED CUT TO FIT; PIPE TO ENG
ACDELCO Part # 14122S {5/8" x 10 13/16" #88907123}
HOSE,MOLDED HTR TO VLV
ACDELCO Part # 16079M {5/8" x 16" #88907321}
HOSE,MOLDED HTR TO PIPE
ACDELCO Part # 18060L {5/8" x 18 3/16" #88907500}
HOSE,MOLDED VLV TO ENG
Found at: http://www.rockauto.com/catalog/rafr...1278480k345572
That site may or may not be trustworthy but as far as I can tell the parts #s are all correct.
Old 01-14-2010, 11:24 PM   #4
Green7mgte
You looking for Valve to engine hose?
Supra FAQ
Supra MKIII FAQ
Old 01-14-2010, 11:27 PM   #5
916MKIIIx2
Yeah pretty much all the hoses in the back of the engine, I also need one that goes from... damn brain fart... I knew what it was 20 minutes ago... the small hose that goes downward from the shiny silver thing that the big radiator hose attaches to... lol If it wasn't raining outside I could tell you what else the small hose going downward was attached to...
Old 01-14-2010, 11:28 PM   #6
Green7mgte
. the shiny silver thing that the big radiator hose attaches to...
thermostat housing
damn i remember seeing a thread about this that lables all the part numbers.. start search this and supra mania. I know its there. ill check my links
Supra FAQ
Supra MKIII FAQ
Old 01-14-2010, 11:31 PM   #7
916MKIIIx2
Ahh, thanks that would have bugged me all day... but yeah, that hose looks like its puffed up about 3x its original size, I actually don't think its a bent hose, but if you happen to know what the inner diameter size of that hose is supposed to be, that would help me out greatly.
Old 01-14-2010, 11:35 PM   #8
Green7mgte
5/8th if i remember correctly. might be bigger.. i think it is. I just took my old one off and brought it to advanced auto parts to match one up. $5.00..
BOOM found it.. check here
http://forums.celicasupra.com/showthread.php?t=33827
Supra FAQ
Supra MKIII FAQ
Old 01-14-2010, 11:38 PM   #9
916MKIIIx2
Yeah I went to take mine in but they told me the size was off due to the bloating of the hose, thanks for that info going to go get that right now! brb lol
too bad I have to wait for the other hoses to come in the mail
Old 01-14-2010, 11:39 PM   #10
Green7mgte
IIRC you should be able to slide your INdex finger up to the FIRST knuckle. the one right under your finger nail snugly. LOL would you like a photo of my hand for reference
Supra FAQ
Supra MKIII FAQ
MK3 supra Hose Techniques silicon hoses Micahwc Shops & Part Reviews 8 12-09-2012 09:03 PM
Coolent hose leak. probably heater core Green7mgte MKIII Supra 7 11-26-2009 04:43 PM
Sm Vac Hose Under Accordian Hose Chromemoly MKIII Supra 3 07-03-2009 01:19 AM
Replacing Clutch reservoir Hose and fixing rock plate (plastic one) Grandavi MKIII Supra 2 09-29-2008 04:49 AM
blew a hose on the way home from school. suprakid91 MKIII Supra 5 11-19-2007 09:11 AM
