Old 08-20-2005, 06:01 AM   #1
joel williams
Guest
Posts: n/a
Hi ppl, i installed a FCD from turboxs on my 89 toyo supra turbo and it seems like it works ok , but it doesnt stop the computer from hitting fuel cut.? i am tapped into the orange wire of the (asst sensor turbo pressure +5v) even if i unplug the vac line to this sensor i still hit overboost fuel cut.? how can this be happenning? am i in the wrong sensor? like i say its on drivers fender labeled asst sensor turbo pressure. like assistant? like maybe there is a primary one that i am not seeing? the only other thing i can think of is my stock boost guage is still connected and pegs at 8psi even know my aftermarket one says i hit fuel cut at 14 psi? any one ever run into this ? any ideas please would be very welcome..
Old 08-20-2005, 08:13 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
turbo pressure sensor is a sensor that tells you how much pressure is in the turbo
i.e. your boost gauge
you need a hks type k fcd for the 7mgte (and it installs at the ecu)
the type k fcd has 5 wires where normal ones for map sensored cars have 4
resell it and buy a type k
wiring instructions are on my website for fcd's
Pics of my build.
Do a diagnostic first!
Old 08-20-2005, 04:16 PM   #3
Guest
Guest
Posts: n/a
ok i will try that, so with this model car its the mass air flow sensor thats triggering overboost when the turbo pressure sensor is disconected at vacume?
Old 08-21-2005, 06:51 AM   #4
suprra_girl
7M POWAH! ;)
you can unplug it, remove it whatever... the turbo pressure sensor will not alter your fuel cut at all... it will only give inaccurate readings on your dashboard
the afm (karman vortex) measures air flow... when too much gets in... it cuts
afm signal goes to ecu
fcd wires into ecu
fcd clamps signal you don't get fuel cut no more
and you have the possibility of detonating if you wack the boost up something silly
have fun
Pics of my build.
Old 08-21-2005, 07:45 AM   #5
1988gte
1988gte is on a distinguished road
dont mean do highjack but does this device also affect air/fuel? I see your reply about denotation. if not how do you fix?
1988gte is offline   Reply With Quote
Old 08-21-2005, 12:04 PM   #6
suprra_girl
7M POWAH! ;)
basically that was a grumpy reply of mine LOL
i have a fcd installed on mine but purely due to my mods i was hitting fc too early... i installed it and never adjusted my boost and also got it dyno'd to ensure it wasn't running lean
if you want to run a fcd, install it, drive it (not boost it) to the dyno... get it checked for air/fuel ratios
if you only have a dyno 3 hours away.....
then it will depend on your mods altho it does vary between car to car
what mods have you done for yours?
Pics of my build.
Old 08-21-2005, 02:20 PM   #7
1988gte
shims to hit a full 8lbs of boost. any recommendations?
Old 08-21-2005, 06:29 PM   #8
Guest
Guest
Posts: n/a
im only running 12 psi now and the air fuel meter has all 4 bars still in the green(rich) so i think im ok to goto 14psi. then im done till i blow this head gasket and replace it with the metal one as far as boost pressure. i just cant get there due to fuel cut, i ordered the hks k3 type so well try that out. you mentioned your website has the wiring instructions but i didnt see them?? maybe you could link it here for me?> thanks for all the info people..
Old 08-21-2005, 09:22 PM   #9
Guest
Guest
Posts: n/a
Originally posted by Guest@Aug 21 2005, 06:29 PM
im you mentioned your website has the wiring instructions but i didnt see them?? maybe you could link it here for me?> thanks for all the info people..
found it thanks.. nice site.. like the repair manual very nice
Fuel pump hanger for 87 supra non turbo rlipp69 Non-Generation Specific Questions 0 06-16-2007 03:23 PM
