Old 01-19-2010, 12:12 AM   #1
jbl1500
jbl1500 is on a distinguished road
Default New Supra owner
Hi I'm new to this forum and also the soon to be owner of a Mk.III Supra. I'm not sure as to which performance parts I should buy for my Supra. I'm not looking for anything too crazy just enough for a light horsepower gain. Any help is greatly appreciated.
jbl1500 is offline   Reply With Quote
Old 01-19-2010, 12:39 AM   #2
916MKIIIx2
Air filter, exhaust, spark plugs/wires and for a little more money but doesn't give any HP boost... a suspension always helps you go faster, and do so without losing control.
Old 01-19-2010, 04:45 AM   #3
jbl1500
Any specific brands you suggest and how much do you think all of it would cost? Thanks man.
Old 01-19-2010, 04:57 AM   #4
916MKIIIx2
I prefer K&N filters, those are fairly easy to find at most performance shops or by searching for them online, same with spark plugs... Though I hear pulstar pule plugs really give a difference. But NGK plugs and wires are also good. You can find air filters at JDM Ultimate for about 50-100 bucks. I got 2 from them, fast delivery and didn't have any problems. All I can really say is search around, prices are different all over the place and most of those parts are easy enough to find and put in.
An exhaust? Ask some dude at an exhaust shop to make you one, its usually the cheapest but not the prettiest looking exhaust, or you can find some online for 500+ for a good one.
Old 01-19-2010, 08:05 PM   #5
jbl1500
If I wanted to Turbo my Supra out which Turbo would you recommend?
Old 01-19-2010, 08:07 PM   #6
916MKIIIx2
I don't really ever suggest aftermarket parts to anyone unless they have the money to do it right. But if you want to turbo a non turbo supra, you definitely want to go the way of the CT-26 and if you're looking for that aftermarket power get a 57trim from suprastore, VERY GOOD turbo I have one and swear by it at 12lbs of boost daily driving.
Old 01-19-2010, 09:28 PM   #7
jbl1500
On the CT-26 does it take a long time to spool?
Old 01-19-2010, 10:45 PM   #8
jbl1500
Also how much does a Mk.III Supra weigh stock?
Old 01-19-2010, 11:12 PM   #9
Krem
the stock weight of the car should be found printed on a sticker on the side of the driver door. As for mods, cheapest, quickest and best options are probably cold air intake and exhaust system... Not sure if grounding straps help these late models, but they're goin' in my mk3 if I ever find out they do.
As for the new supra thread... grats on your new mk3. I see the same thing WAAAAAY too often tho, and am even guilty of it myself. Someone gets a new mk3 and gets gung ho with hopes and dreams of making it a kick ass 420hp @ the wheel beast.. Firstly, you'll only get that high of power on a turbo engine. Secondly, Toyota screwed up some info in their manuals which have caused problems in the past.. mainly the torque settings they specified for the head bolts is waaaay under torque, giving you greater chance to blow that head gasket. If you've gotten a garage kept, sunday driver, from an owner who babied the car since the late 80's/early 90's.. awesome deal. However, in the more likely event this wasn't in mint condition already, you should check things on the mk3 first. Check the radiator for flow, debris and give a pH block test to see if your head gasket is ok. Do your timing... I even had to do my timing and when I bought the car it was working great. Other than that, I think you should be ok. The 7m heats up like a forge, I'd definitely make sure the cooling, if nothing else, is up to performance levels. I still need a fan & shroud assembly (or a shroud and new fan clutch) to fix my cooling... Good luck to you.. and welcome to the wide world of the mk3 Supra.
Note: If you have a 7mgte already, you shouldn't really have to worry about what turbo anyone would recommend... unless you're upgrading. However, the 7mge block MIGHT be able to take a turbo, but from what I've read, it's not worth it nor is it advised due to the compression ratio on the 7mge. The compression ratio in the 7mgte was made to account for turbo, the 7mge was not.. I guess if you wanted to do some work on the block yourself, you could make it happen...
Old 01-20-2010, 12:05 AM   #10
jbl1500
Thanks for the advice I really appreciate it. I don't have my Supra just yet what could I take out for a weight reduction?
How long have you been a supra owner? jcastro MKIII Supra 23 10-24-2009 11:25 PM
New supra owner (not running) here What to do next Gengus MKIII Supra 1 11-12-2007 03:46 AM
Possible supra owner questions! Zanark MKIII Supra 2 08-24-2007 06:01 AM
New to this forum(not a supra owner though) Supra spotted in tucson. z33 DaRkNeSs Off Topic Forum 5 08-28-2006 11:16 AM
