Old 01-25-2010, 04:10 AM   #11
gteduck
gteduck is on a distinguished road
Originally Posted by bryanf89 View Post
ok gteduck let me see if i got this correct....tuning the cam to a positive range will retard my timing allowing my engine to achieve higher rpm thus producing more hp in higher gears but the trade off is not having smooth timing on low steady rpm and tuning my cams to the negative range will my advance my timing allowing for quicker acceleration in lower gears but losing out on top speed and power in higher gears...is my knowledge on this correct?
lol if there was thing i want to do to my supra is definatly rebuild the engine give that baby a new heart a modified heart that is lol
LOL !!! advance/plus/low revs
retard/minus/higher revs ( i'm pretty sure )
it makes no difference what gear your in, the engine still behaves the same way.i don't know about you but when i give it shit the revs never drop below 3000 to 3500. HEY you only get lag once at worst, if you stay on the pedal a keep the snail winding there is no such thing .lol
gteduck is offline   Reply With Quote
Old 01-25-2010, 06:20 PM   #12
There a lot more to it than just advancing and retarding to shift the output peaks... Cam tuning has little to do with the EMS employed, you'll get more out of it that way, but there's no problem with tuning your cam timing on the stock EMS.
Read this:
http://www.supraforums.com/forum/sho...d.php?t=411951
Old 01-25-2010, 06:51 PM   #13
bryanf89
I can always count on cre lol
Old 01-26-2010, 03:30 PM   #14
gteduck
about time you put in cre, my head was going to explode trying to explain what it does, all i know is what it did to my donk , NOT HOW OR WHY!!!
aaaaaahhhhhhhhhh that's better.
Old 01-26-2010, 06:03 PM   #15
Adjustable cam gears can get you a bit more power out of the stock cams, but they really shine when tuning a set of more aggressive cams.
Old 01-28-2010, 08:00 AM   #16
gteduck
i found a really good thread called 'cam tuning' i think , at 'celicasupra.com' . It was in the section for M series engines, IT might be in FAQ if it's not there, do a search, it was quite indepth. It should tell you all you want to know.
happy hunting!
Tags
fidanza cam gears, timing
Aftermarket gauge cluster? djblanco MKIII Supra 2 09-26-2011 02:15 AM
Best bang for your buck aftermarket supra parts j_moy_08 MKIII FAQ 86 01-21-2011 06:38 PM
I have an aftermarket exhaust.... Aghhh redmaro MKIII Supra 1 11-20-2006 05:38 PM
Rear end gears. TxSpeedBoy Non-Generation Specific Questions 0 02-08-2006 06:12 PM
