Deleted-----
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein 1988 and 1990 Turbo Supras Last edited by Benesesso; 02-06-2010 at 03:03 PM. |
I'm not too sure about the stock boost sensor, but if it does have a vacuum line that runs to the gauge then that could have come undone from the gauge itself. I had this happen to me on my aftermarket boost gauge.
The gauge is electric. The sensor is located up behind the driver's side wheel well, right in front of the cruise control actuator... they share the same vac source.
Nope, not from the factory anyway. It's possible you're hearing a massive boost leak through the firewall, or something electrical that's buzzing.
#5 | |||
![]() Quote:
WTF? It's stupid shit like this that's why no one's ever going to be able to help you... did you just forget that YOU added a vac line where the NEVER WAS ONE? Jebus..... Quote:
#6 |
There is NO stock vacuum line run past the firewall... none.
I said stupid shit because YOU posted and asked where the vac line was... I told you, then you argue that it has to be behind the dash because that's where the hissing is... THEN you admit to having put a vacuum line behind the dash yourself... And now you try and twist everything I said about the noise possibly coming from the stock gauge and you seemingly ignore the part about diagnosing your mechanical gauge (the diaphragm is in YOUR gauge, if it holds pressure, you test the hose next)????? No worries though. I haven't the patience for this right now, so I'll step aside. Good luck with the problem.
Dream Offer | Karma_Supra | MKIV Supra | 22 | 10-17-2007 03:04 PM |
Sequential Turbo Question | suprapoweredsoarer | MKIV Supra | 1 | 06-06-2006 12:13 AM |
