Old 01-27-2010, 04:04 PM   #1
ccwade
ccwade is on a distinguished road
Talking Head gasket specs
I searched thru the posts and I didn't see one that lists the stock specs for the head gasket. Thickness and bore size. Does anyone know if the Fel-Pro part # HS9473PT-1 comes with a MHG and what are the specs to that head gasket? I can't find any info on this.
Any help would be greatly appreciated.
ccwade is offline   Reply With Quote
Old 01-27-2010, 05:31 PM   #2
reydio
reydio is on a distinguished road
Fel-Pro is similar to Toyota stock, not MHG. You can get MHG from Cometic, HKS, Titan Motor Sports. Depending on the current condition of your head and block will determine what thickness MHG you will need. Your best bet is to consult your machine shop. As for stock and daily use, Fel-Pro is good.
reydio is offline   Reply With Quote
Old 01-27-2010, 10:56 PM   #3
ccwade
Smile
Does anyone know what the stock thickness of the head gasket is for a 91 turbo? Do you know how I can tell which bore thickness I have on my car?
The description on autoparts warehouse for the felpro kit states that it come with a multilayered metal head gasket.
http://www.autopartswarehouse.com/mm...ket~parts.html
Old 01-29-2010, 04:50 AM   #4
kamikazemkiii
kamikazemkiii is on a distinguished road
1) Stock HG = 1.37mm compressed
2) Stock head = 116mm deck to valve cover surface
3) Stock block = 198.5mm from deck to main bearing saddle
If 2 and 3 are less that amount needs to be added to 1 to retain the stock compression ratio and squish/quench.
stock bore is 83mm
kamikazemkiii is offline   Reply With Quote
Replacing the Head Gasket SupraDietrich MKIII Supra 17 11-09-2005 01:57 AM
