I searched thru the posts and I didn't see one that lists the stock specs for the head gasket. Thickness and bore size. Does anyone know if the Fel-Pro part # HS9473PT-1 comes with a MHG and what are the specs to that head gasket? I can't find any info on this.
Any help would be greatly appreciated. ![]() |
#2 | |
![]() Quote:
#3 | |
![]() Quote:
The description on autoparts warehouse for the felpro kit states that it come with a multilayered metal head gasket. http://www.autopartswarehouse.com/mm...ket~parts.html |
1) Stock HG = 1.37mm compressed
2) Stock head = 116mm deck to valve cover surface 3) Stock block = 198.5mm from deck to main bearing saddle If 2 and 3 are less that amount needs to be added to 1 to retain the stock compression ratio and squish/quench. stock bore is 83mm |
Blown Head Gasket? | BillW | MKIII Supra | 5 | 09-17-2010 02:06 AM |
1989 Supra blown head gasket | rayk5799 | Non-Generation Specific Questions | 6 | 05-18-2009 10:51 AM |
Head Gasket replacement questions. | DavidLeClair584 | MKIII Supra | 1 | 06-09-2007 09:17 PM |
Buying a 87, head gasket questions | Gengus | MKIII Supra | 1 | 04-14-2007 07:15 PM |
Replacing the Head Gasket | SupraDietrich | MKIII Supra | 17 | 11-09-2005 01:57 AM |
