Old 08-21-2005, 07:36 AM   #1
1988gte
1988gte is on a distinguished road
Okay Im new to the turbo thing. I have a 04 mustang mach 1 (32 Valve V-8) I posted about a month ago about some questions on my 88 supra turbo, anyway got it running all that good stuff. So what is a turbo elbow, downpipe? Is it the exhaust, goes to the exhuast? I am going to change my exhaust anyways from im guessing the turbo down and i see this info about the turbo elbow, downpipe. http://www.toyota-supra.info/forums/index....t=ST&f=4&t=1590 I just want somebody to explain it to me. I have read steve119md post about the manifold which just brings more questions do you want 2.5 to 3 inch or 3 to 3 inch I see many manifolds on ebay any feedback would be great
1988gte is offline   Reply With Quote
Old 08-21-2005, 10:31 AM   #2
ddmcse
ddmcse's Avatar
+bigger is better with a turbo
if you've ever seen a stock elbow (90 degree bend right off the turbo ) you'd have noticed that it's got a major blocked wall inside it .
if you are going to work on the exhaust i would make the elbow part of your plans for sure .
a google will prolly shopw you some before and after shots of the elbows
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 08-21-2005, 12:06 PM   #3
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
it's exactly as you see it.... it's the part that bolts to the back of the turbo and to your exhaust downpipe.... a massive improvement upon stock
Pics of my build.
Do a diagnostic first!
Old 08-22-2005, 12:07 AM   #4
Poodles
Poodles is on a distinguished road
It all depends on what you want to do, the elbow is restrictive, but the downpipe is REALLY bad becuase the pre-cat in it usually clogs. You can go with a new downpipe and elbow, or a elbow/downpipe that is one piece, or even better IMHO is a divorced downpipe which vents the wastegate to atmosphere instead of into the exhaust system. A lot of cars do that anyways, sounds better, and allows the exhaust to flow the exhaust only, and not the exhaust and excess boost from the turbo, which can kill the flow.
Such is the disadvantage of an integrated wastegate...
Poodles is offline   Reply With Quote
Old 08-22-2005, 11:21 PM   #5
joel williams
Guest
Posts: n/a
ya i knocked out the platinum innards of both cats and it just so happends a 2.5 inch pipe slides right in to both cats. weld it up and looks like cats are still there wowser what a difference.. so thats what the turbo is supposed to spool up like???. he he he !!! and its still a very quiet sleeper...now i am machining my own 90 elbow from an extra one i had laying around.. should free up the rest, cant wait. yehaaa h34r:
Old 08-23-2005, 03:52 AM   #6
Luin Haden
Luin Haden's Avatar
Luin Haden is on a distinguished road
what did you knock it out with? How easy was it?
-Luin Haden
Sparta, MO
Owner of a 1990 Targa Top 5 speed Turbo Supra
It isnt pretty now, but just wait.
Luin Haden is offline   Reply With Quote
Old 08-27-2005, 05:48 AM   #7
1988gte
anybody know where to get a downpipe, devorce downpipe, elbow/downpipe (one piece)? can you go to a mufflershop and have them make you a downpipe? :huh:
Old 08-27-2005, 06:53 AM   #8
Poodles
http://www.bicperformance.com/
Old 08-27-2005, 08:48 AM   #9
joel w
joel w's Avatar
just a big rock bar. its like ceramic material, i think its actually platinum bust up and falls out. then remove the screen liner and sleeve it.. i
Old 08-28-2005, 08:02 AM   #10
Poodles
yeah, most cats are ceramic on the inside, the metal matrix ones are the best you can get, and if you want to upgrade, get the lowest openings per square inch, as it will flow more. I wouldn't break up a good cat though...
downpipe question boogum7 MKIII Supra 5 11-06-2006 02:32 AM
3" Downpipe Reeves MKIII Supra 10 08-31-2006 10:35 PM
Divorced Downpipe VS. 1 piece elbow-downpipe 87sleeper MKIII Supra 1 10-04-2005 04:50 PM
