Old 01-30-2010, 11:56 PM   #1
kaseysmom
kaseysmom's Avatar
kaseysmom is on a distinguished road
Default Engine Restore
I would like opinions on the use of this product. The good the bad and the ugly are all welcome! I am more of a sea foam gal (you can give me your opinion on that also) but my husband wants to put the engine restore in my MK3 turbo with 160,000 on it. I think it is just time to rebuild it - but I don't want to use anything that will harm the engine. Thanks!
On life's journey faith is nourishment, virtuous deeds are a shelter, wisdom is the light by day and right mindfulness is the protection by night. If a man lives a pure life, nothing can destroy him.
kaseysmom is offline   Reply With Quote
Old 01-31-2010, 12:10 AM   #2
mirage83
It's snake oil in a can. It probably won't do any harm, but in a well-worn engine there's no real fix for worn bearings, thinned rings, tired oil pumps and bad valve seals other than replacing them.
Sea Foam is pretty much in the same category... might not do any serious harm, but there are better options out there for cleaning your fuel system. Techron (for example) is one of them.
Old 01-31-2010, 12:39 AM   #3
I agree with Mirage... it's crap. I'm also anti sea foam. Run good fuel with good detergents and even better oil with excellent additive packs and you'll never need any of that garbage. Sea foam's 90% Naptha... if you want something cheaper which is just as caustic and also eats rubber try bathroom caulk remover... It does just as good cleaning buildup and eating seals.
Old 01-31-2010, 07:23 AM   #4
kaseysmom
kaseysmom's Avatar
Default Thanks!
I think that is enough information to make an intelligent decision - Thanks! My first and last thought now on the subject is to tear it down and fix it. Especially since the compression is really bad across all six cylinders. Time to take a look inside to see how bad it is!
Old 01-31-2010, 07:33 AM   #5
Poor compression across the board? Did it remain the same with a wet test?
Old 01-31-2010, 07:37 AM   #6
kaseysmom
kaseysmom's Avatar
Default Pretty much
In the wet test the numbers only went up about 30 - still way too low to be considered even close to normal.
Old 01-31-2010, 07:50 PM   #7
kaseysmom
kaseysmom's Avatar
How bad is bad? I figured I would just give them to you rather than wait for you to tell me to post them. 70 - 60 - 50 - 25 - 25 - 50. I was not with my car when it was tested - my husband did it following the TSRM instructions. He said he did a wet test on 2 of them (which two I am yet to find out) and the numbers went up about 30 psi. If he ever decides to get up I will go back to the shop with him and run it again to be sure.
Looks like a bottom end problem? Piston rings, cracked pistons, scored cylinder walls? LOL! Don't think they are selling anything in a bottle to help me out of this! So is it rebuild time - or what?
Old 01-31-2010, 08:14 PM   #8
mirage83
That would be pretty bad, as IIRC the GTE should run about 140. Even a 70 is pretty poor, and any cylinder reading out at 25 or so probably doesn't have much left in the way of rings and may even have suffered some piston damage to one degree or another.
Personal opinion? Plan on a full rebuild, top to bottom, along with all the various cracked or cracking hoses (vacuum and water) and assorted frayed/cracked wires you'll undoubtedly come across when the engine is pulled.
With compression that poor and uneven I don't really see much choice other rebuilding yours or swapping in another engine. At least if you rebuild it or have it rebuilt you'll know what quality parts are going into it, and with a swap you may or may not have that sort of assurance and confidence in the engine.
Old 01-31-2010, 08:40 PM   #9
kaseysmom
kaseysmom's Avatar
Default Thanks!
That is what I have been thinking all along. I have another 90 hard top with no engine or transmission but a really nice interior and exterior. I was hoping to be able to drive the one I'm currently driving long enough to do a swap - rebuild combo and get them both on the road - but it doesn't look like that is happening. And I like the idea of the do it yourself way since I plan to keep the car forever! Or until someone hits me! LOL!
Old 02-03-2010, 06:31 AM   #10
supradaddy0803
supradaddy0803's Avatar
Ummmmm personnel opinion if you got the know how. (Coughs) 1JZ lol. after you get past the ECU problem or buy a motor set that has had the Caps changed its a way more reliable engine. Like I said personnel opinion. But if you dont have the know how it is a really fun swap TRUST ME. but seeing as you have a 90 you will have a lot easier time than I have had.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Tags
engine restore, oil, rough idle, seafoam
