Old 02-01-2010, 03:03 AM   #1
jaime
jaime is on a distinguished road
Exclamation Buying a mk3 n/a supra
Hello guys,
I am kinda new to the mk3 supra world so i am not informed about it until a couple days ago that i was offered one and started researching it a little bit. i am going to need advice from you guys on this buy.
A friend of mine offered me his 1987 supra n/a for $1000. He said he's had the car since 1991 and has been garage kept most of the time, that is very well taken care of. It has 140,000 miles and he said the engine has just been rebuilt and that it's still under warranty for a couple more months. I don't recall exactly but i thought i heard him say it was a 89 engine or something like that. it has a 5 speed transmission. Thats all i know, i am supposed to meet with the guy this Friday to check it out. I've been a supra fan ever since i first saw it, and i always wanted one, well a mk4 anyways but i guess i can settle for a mk3 for right now since money is kinda tight. i would definitey want a fast supra but i am kinda lost right now, reading about engines swaps and all that good stuff. First of all is it a good buy? Would it get expensive doing an engine swap? Anything i should check for?
Please guys, talk me in to it or out of it if i should. I need your help!!!
thanks in advance.
jaime is offline   Reply With Quote
Old 02-01-2010, 06:22 AM   #2
gorillaguy8
gorillaguy8's Avatar
gorillaguy8 is on a distinguished road
Well I definitely love mine, I bought it in crappy condition and then gave it a lot of elbow grease. It still has an issue once and a while but its fun to drive and a fun little project to work on here and there. I would recommend that you get it, for only $1k thats a steal.
Black 87 N/A, re-built from the ground up.
gorillaguy8 is offline   Reply With Quote
Old 02-02-2010, 12:06 AM   #3
brad88supra
brad88supra's Avatar
brad88supra is on a distinguished road
Sounds pretty cheap for a freshly rebuilt engine, does it need cosmetic work or somethin.
1988 N/A Supra, 5 speed, Targa top, Tems
brad88supra is offline   Reply With Quote
Old 02-02-2010, 12:13 AM   #4
mirage83
MkIII N/A's aren't all that fast, though insurance is definately cheaper on them and they are still fun to drive in addition to looking sharp.
Engine swaps are generally expensive, as it's never just a case of pulling and swapping... there's always more involved when you get into it. If the N/A is an issue, I'd hold out until you find a GTE in your price range.
It could be a good deal, depends on the exact condition of the engine as well as the body, interior, tranny, differential, etc. Hard to say.
Old 02-02-2010, 01:38 AM   #5
I would start by doing a compression test.
Old 02-02-2010, 03:42 AM   #6
jaime
I really doubt there is any body damage, but again I haven't seen the car but i asked the guy if there was anything wrong with it, he said "all it needs is a new battery and an inspection". I will be seeing and checking it out on Friday and I definitely plan on taking it on to a mechanic to get it inspected. He said its been sitting on his garage for a while.
Old 02-02-2010, 03:47 AM   #7
the affect of "sitting" itself has negative effects on the brakes and braking system. but man the major thing I would check out is the rebuilt engine and any electronic issues. those are pains. everything else is something to do in your free time.
Old 02-02-2010, 11:37 AM   #8
mirage83
Don't forget the fuel system. Depending on just how long it sat and how much gas was in the tank, the tank and fuel pump could be corroded to junk like it was in mine when I first began working on it. Also, the injectors might need a thorough cleaning.
Tags
new supra, supra help
Possibly buying an '83 Celica Supra SilverWolf072 MKII Supra 0 01-15-2010 09:49 PM
Thinking of buying a used modified Supra holliskingdee MKIV Supra 1 12-12-2009 12:45 PM
I'm looking at buying a Supra (new to forums) feelthejoy MKIV Supra 0 07-02-2009 07:25 PM
buying a supra docvtak MKIV Supra 6 11-16-2005 01:29 PM
