Old 08-23-2005, 06:56 PM   #11
SupraDave
SupraDave is on a distinguished road
low octane gas can cause detonation because the fuel ignites at lower temp.
Why is this a problem?
1. The extreme pressure cause by detonation can ruin engine bearings, bend/score the crankshaft, bend the connecting rods etc..
2. ECU can only correct air fuel mixture and timing to a certain point and once outside the ecu's ability to correct the degradation of performance is increased greatly.
3. Poor combustion increases emissions which can choke a cat.
Remember:
High compression + engine age = higher octane requirement.
SupraDave is offline   Reply With Quote
Old 08-24-2005, 03:53 AM   #12
Poodles
Poodles is on a distinguished road
manual says at LEAST mid grade, high grade is recommended though. It's a few cents more, but it's better than detonation and all the things that break with it (and the cost to fix what breaks)...
Poodles is offline   Reply With Quote
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel Octane scruffboy Non-Generation Specific Questions 3 09-08-2006 06:49 PM
Fuel injectors Biku Off Topic Forum 7 07-23-2005 04:36 AM
