Old 02-08-2010, 01:57 AM   #11
Well, a death whine sounds different than a boost leak which sounds different than an exhaust leak... still could be any of the above.
When you check the turbo there really shouldn't be much movement in any direction. If there's more than 1 to 1.5mm it's in need of a rebuild, more than 2 to 2.5 and it could be whining and possibly beyond rebuilding. Check if the impeller is making contact with the compressor housing in any spot... if it is check for missing material, don't want shavings making it past the IC and into the engine.
Old 02-08-2010, 04:36 PM   #12
supraluver4life
supraluver4life is on a distinguished road
alright great. i really dont know how much movement there is, but its probably about 1mm to 1.5mm and the turbine isnt touching the housing anywhere, so would you suggest a rebuild?
thanks again
Cusco front, Tein Rear coilovers
Massive DDP, 3'' custom catless exhaust, Tsudo muffler 4.5'' outlet, Apexi cold air intake, Act stage 3 clutch, ct26 turbo (stock)- 10psi
+300rwhp
"Not driving a car because its too nice, is like not fucking your gf so shes still tight for the next guy"
supraluver4life is offline   Reply With Quote
Tags
boost
constant boosting problem supranutz MKIII Supra 4 12-06-2009 02:57 PM
Boosting my 88 7mge lemonhead4696 Non-Generation Specific Questions 5 07-02-2008 02:24 AM
weird coolant leak kusupra3 Non-Generation Specific Questions 1 06-29-2008 07:48 PM
weird sounds when car moves Donovan MKIII Supra 10 06-08-2007 11:14 PM
boosting turbo steve119md MKIII Supra 2 09-15-2005 11:09 AM
