Old 02-06-2010, 03:02 AM   #11
Just leave all the adjustments at "0" and you're fine.
Old 02-06-2010, 03:10 AM   #12
Green7mgte
Supra Forum Moderator
here is the pin for the ecu. and the wire diagram for Karman engines such as ours.
ID:	2764   Click image for larger version
Old 02-07-2010, 12:09 AM   #13
Green7mgte
man I spent about 3 hours out there today. hooked everything up according to the print out and blah, nothing on start up and I had the all clear code flashing on my dash. maybe something wasn't connected as securely as it should of been. idk. but now im a little sad. cold and hungry. oh and my dash is still torn apart and I have to work at 6am tomorrow.
im including this link
http://www.snapdrive.net/files/91304...SAFR_MKIII.pdf
more informative then the others above.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 02-07-2010, 05:06 AM   #14
You do still have to setup the SAFC's system for the 7M-GTE... you just don't touch any of the tuning specific settings.
Old 02-09-2010, 03:24 AM   #15
Green7mgte
There isent a chance I was looking at this thing upside down could I.? shoot I hope not. when i first accessed the ecu the sticker was facing me. that is me on my back looking up, hah. would looking at it this way be the top of the ecu? so I would of actually had the connections "flipped." that would explain it not turning on.
I used the diagram of the pinout above. and treated it as tho it was still plugged in. example. Rpm signal, first plug, top row, third from the right. and did the same. Unplugged the first harness. top row, grabbed the wire third from the right. (first harness being closest to glove box)
Supra FAQ
Supra MKIII FAQ
Old 02-09-2010, 10:08 AM   #16
Just open the TSRM to the EFI section and locate the ECU pinout... use that and ONLY that to find the wires you're looking for. The diagram shows the pins as if you're looking into the ECU, so, for the plug you look at the back side where the wires run in. Shouldn't behaving any trouble due to things being flipped, there are pictures of the clips on the plugs so you know what end it up.... just unplug all three, solder/crimp in the new connections and you're done... this really is a 5 minute job... Your next one will be, I promise.
Old 02-18-2010, 08:56 PM   #17
Green7mgte
the problem definitely was with my connections. I went through again and made secure crimps using butt connectors and heat shrink. wrapped all the connections in electo tape and used male / female connections for the air pressure connections. held my breath and turned the ignition key on. boom got lights. stays on and reads correctly. hopefully the links and diagrams and the trouble i went through will be helpful to someone else as green as me to install this unit correctly.
now to go put my glove box back together .
-regards
ps. you can clean this up and remove all the ranting. might make a good faq thread.
Supra FAQ
Supra MKIII FAQ
Question regarding a DVD installation Grandavi MKIII Supra 0 08-12-2009 01:39 AM
K&N FIPK installation guid with pics azerty MKIII Supra 1 05-04-2008 02:12 PM
Speaker Panels Installation, HELP minusthecoop MKIII Supra 0 04-13-2008 09:43 PM
Alternator belt removal and installation! ~*B Magical*~ MKIII Supra 11 03-13-2008 07:27 PM
wideband o2 installation Burning Pyro MKIII Supra 1 08-29-2007 11:34 PM
