Old 02-07-2010, 11:08 PM   #1
kadinz
kadinz is on a distinguished road
Default top end knocking
just got my car up n runnin, drove it about 300miles and one day when i got back from lunch at work BAM! car shuts off, well i start it up and its goin ding ding ding ding ding ding ding ding, not a bottom end noise but its pretty bad and i lose enough power to the point it wont shift out of 2nd, heres a video.. im gonna take the valve cover off tomorrow and check whatsup, mechanic at my shop said lifter but idk..sounds like too much noise for a lifter..
http://s398.photobucket.com/albums/p...5-11-14-28.flv
any ideas?
kadinz is offline   Reply With Quote
Old 02-07-2010, 11:45 PM   #2
Dear God!!! Don't run that!!!!
Sounds like it spit out a shim to me as well... the sound like rattling pocket change gives it away.
If it is a shim don't be surprised if you need a new cam.
Old 02-08-2010, 02:11 PM   #3
kadinz
that sounds gorgeous... uhh so i should replace a few valves and you think theres bad lifters too?? and possibly a cam.. im just tryin to get this asshole running for now, ill be doing a complete bottom end reinforcement and head rebuild around summer but for now i need it to get to work and back -_-
im gonna need to drive it to my friends house about 3 miles away to get into a heated garage with tools.. would that be horribly bad to drive it that distance? we should have the valve cover off today.
Old 02-08-2010, 11:20 PM   #4
mirage83
Tis up to you dude. If I were you though I might want to consider towing it since every revolution of that cam is going to increase the possibility of damage to the head or it's components. From the sound it's already "bad", so it's just a question of how willing you are to risk driving it from "bad" to "worse".
Feel lucky punk?
Old 02-09-2010, 02:33 PM   #5
kadinz
Feel lucky punk?
i felt lucky, but 2 miles later the engine didnt wanna comply and basically revved real high, let off the gas...knocking stopped i pressed the gas again and DING! locked. i was driving it to the place thats replacing the engine completely, ohwell...out another 145bux for a tow but whatever ill have a car in 2 weeks.
Old 02-09-2010, 05:02 PM   #6
It could trash the whole engine... lots of metal getting shredded and the material getting dumped right back into the main system.
Old 02-09-2010, 07:20 PM   #7
Green7mgte
Supra Forum Moderator
whoa. i just would of towed it. 60 bucks. vs.. possible engine destruction. damn to bad you didn't record that. good luck tell us how it goes.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
knocking around 2000-3000rpms Suprafreak MKIII Supra 11 03-24-2009 06:45 AM
Hard Engine Knocking 86SupraMan MKIII Supra 10 09-14-2007 05:39 AM
funny knocking sound on 7mge Jeff_5_7 MKIII Supra 11 09-09-2007 01:22 AM
Help with knocking on front end supra96 dini_the_owl MKIV Supra 8 09-03-2006 10:24 PM
knocking block, want to build solid bottom, what should i use alcbarrios MKIII Supra 1 04-14-2006 04:16 AM
