#1 |
so i bought a supra a while ago with the engine out and it had a bhg so i replaced that and the head. So i finally got the motor and tranny in and the wiring that i know of and can see done up. when to go start it i had no power at the coil. traced that back to an unplug ignition wire. went to go crank again and still have no spark. so i went to the toyota service manual and went for the no spark condition and started doing testing and found the ignitor to test bad. Replaced the ignitor and i still have no spark.
I am at a lost of what it could be. Any ideas? I know there are guys out there that know alot more about the supras then i do and could prob give me hints on where to start. By the way its a 1990 supra with a 7mgte. the cylinder head is off a jdm 7mgte and its not running the egr system and it has arp head studs along with the third verison of toyotas gasket thanks in advance |
#2 |
anyone have any ideas
#3 |
![]() Toyota Racing Development Join Date: Apr 2007
No error codes? Manual or automatic transmission? Is there power at the ECU? Does the check engine light up when the key is in the "ON" position but the car is still off? Are the ground wires which connect to the head on the passenger side and the intake manifold on the driver's side all clean and securely fastened?
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#4 |
havent checked for codes yet. ground on the passenger side is good and didnt know there is suppose to be one on the intake... where on the intake does it bolt to and where on the car?
#5 |
and its manual trans
#6 |
The other ground I mentioned consists of two eyelets (4 wires, IIRC) and they connect to the bottom of the lower intake plenum (driver's side of the head).
Check for codes, it'll help see if there are any power supply issues at the ECU.
No spark mystery on 7mgte | jcgrant4 | MKIII Supra | 9 | 08-19-2009 06:21 PM |
No spark issues | DDBT | MKII Supra | 2 | 01-06-2009 07:08 AM |
7mgte swap no spark | supra4life1386 | MKIII Supra | 5 | 11-27-2008 07:57 PM |
NGK Spark Plugs | 91 Supra | MKIII Supra | 5 | 08-07-2007 03:52 AM |
