Old 02-12-2010, 08:27 PM   #1
supra.7mgte
supra.7mgte is on a distinguished road
Default 7mgte no spark
so i bought a supra a while ago with the engine out and it had a bhg so i replaced that and the head. So i finally got the motor and tranny in and the wiring that i know of and can see done up. when to go start it i had no power at the coil. traced that back to an unplug ignition wire. went to go crank again and still have no spark. so i went to the toyota service manual and went for the no spark condition and started doing testing and found the ignitor to test bad. Replaced the ignitor and i still have no spark.
I am at a lost of what it could be. Any ideas? I know there are guys out there that know alot more about the supras then i do and could prob give me hints on where to start.
By the way its a 1990 supra with a 7mgte. the cylinder head is off a jdm 7mgte and its not running the egr system and it has arp head studs along with the third verison of toyotas gasket
thanks in advance
supra.7mgte is offline   Reply With Quote
Old 02-16-2010, 12:15 AM   #2
supra.7mgte
anyone have any ideas
Old 02-16-2010, 01:56 AM   #3
No error codes? Manual or automatic transmission? Is there power at the ECU? Does the check engine light up when the key is in the "ON" position but the car is still off? Are the ground wires which connect to the head on the passenger side and the intake manifold on the driver's side all clean and securely fastened?
Old 02-17-2010, 02:07 AM   #4
supra.7mgte
havent checked for codes yet. ground on the passenger side is good and didnt know there is suppose to be one on the intake... where on the intake does it bolt to and where on the car?
Old 02-17-2010, 02:09 AM   #5
supra.7mgte
and its manual trans
Old 02-17-2010, 02:44 AM   #6
The other ground I mentioned consists of two eyelets (4 wires, IIRC) and they connect to the bottom of the lower intake plenum (driver's side of the head).
Check for codes, it'll help see if there are any power supply issues at the ECU.
Old 02-17-2010, 03:47 AM   #7
supra.7mgte
alright thanks man ill check tomorrow
Old 02-17-2010, 04:15 AM   #8
bradenman1
bradenman1 is on a distinguished road
Check to make sure the coil packs are grounded well. when i took mine apart the ground wire was half way decentagrated and the wire was bare. im sure it was causing some of the problems i was experiencing while the car was running but i wont know for sure until i get my new manifold and get her all back together
Cars:
1995 NIssan altima with 2 year old pant on black Drag DR-8 17x7 Wheels with brand new Goodyear Eagle GT's
Custom Blue Parking lights with White silverstar head lights
JDM Ebay Catback Exhaust.
K&N air filter.
(Totaled Due To An Idiot)
bone stock (for now) 1990 Supra Turbo With a brand new CT-26 Turbo And New Exhaust Manifold. Now With A Brand New Blown Head Gasket
Now driving a 99 Nissan Maxima 5spd with the passanger side bashed in from passing out at the wheel nice cars ehh??
bradenman1 is offline   Reply With Quote
Old 02-17-2010, 05:06 PM   #9
MA70-3.0GT
MA70-3.0GT's Avatar
you took the words out of my mouth there, it's easy to overlook this earth especially if (as with mine) it's broken off the coil carrier. IIRC the coils have their own dedicated earths anyway but Toyota fitted the single wire one for a reason I guess...
Old 02-17-2010, 07:15 PM   #10
supra.7mgte
where exactly is this ground ground on the coil suppose to be... im pretty sure i dont have on and when i bolt the coil carrier down i never have the rubbers that hold it into place so i just used some washers for now.. is that a big deal?
No spark mystery on 7mgte jcgrant4 MKIII Supra 9 08-19-2009 06:21 PM
No spark issues DDBT MKII Supra 2 01-06-2009 07:08 AM
7mgte swap no spark supra4life1386 MKIII Supra 5 11-27-2008 07:57 PM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
