Old 02-12-2010, 11:34 PM   #1
98poop
98poop is on a distinguished road
Default boost cut
I have a 87 i shimed the wastegate and i get some sort cut out at 5 pounds help just read how to check codes there 34 43 now what
98poop is offline   Reply With Quote
Old 02-13-2010, 01:16 AM   #2
mirage83
The ECU is telling you that it doesn't care for the shimmed wastegate.
Code 34
* The turbocharger pressure is abnormal.
Trouble Area
  • Turbocharger
  • Air flow meter
  • ECU
  • Intercooler system
Code 43 is something totally unrelated in all likelyhood.
* No "STA" signal to ECU until engine speed reaches 800RPM with vehicle not moving.
Trouble Area
  • Ignition switch circuit.
  • Ignition switch
  • ECU
Well, unrelated unless your ECU is going Tango-Uniform.
Old 02-13-2010, 01:34 AM   #3
Most likely you've created a boost leak. Check all of the couplers you've moved and those near them for tears and make sure they're securely fastened.
Old 02-13-2010, 01:58 AM   #4
98poop
I didnt unhook anything
Old 02-13-2010, 02:02 AM   #5
Okay... doesn't really change what you need to do as far as diagnostics is concerned.
Old 02-13-2010, 02:17 AM   #6
98poop
Is there a way to check all the can i spray starter fluid on it and c if it revs up i ran a getto intake im going to get a real one tomarrow could that b the problem
Wont accelerate under boost, misfires, backfires, and wont idle Andrew - turbo a MKIII Supra 1 07-24-2009 01:39 PM
wont hold boost Supraman MKIII Supra 12 04-19-2007 04:52 AM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
installing manual boost controller 1989?? hamburgler MKIII Supra 4 07-13-2005 12:55 PM
No boost in neutral but boost in gear! edgardo MKIII Supra 5 10-09-2004 04:01 AM
