Old 02-12-2010, 11:34 PM   #1
98poop
98poop is on a distinguished road
Default boost cut
I have a 87 i shimed the wastegate and i get some sort cut out at 5 pounds help just read how to check codes there 34 43 now what
98poop is offline   Reply With Quote
Old 02-13-2010, 01:16 AM   #2
mirage83
The ECU is telling you that it doesn't care for the shimmed wastegate.
Code 34
* The turbocharger pressure is abnormal.
Trouble Area
  • Turbocharger
  • Air flow meter
  • ECU
  • Intercooler system
Code 43 is something totally unrelated in all likelyhood.
* No "STA" signal to ECU until engine speed reaches 800RPM with vehicle not moving.
Trouble Area
  • Ignition switch circuit.
  • Ignition switch
  • ECU
Well, unrelated unless your ECU is going Tango-Uniform.
Old 02-13-2010, 01:34 AM   #3
Most likely you've created a boost leak. Check all of the couplers you've moved and those near them for tears and make sure they're securely fastened.
Old 02-13-2010, 01:58 AM   #4
98poop
I didnt unhook anything
Old 02-13-2010, 02:02 AM   #5
Okay... doesn't really change what you need to do as far as diagnostics is concerned.
Old 02-13-2010, 02:17 AM   #6
98poop
Is there a way to check all the can i spray starter fluid on it and c if it revs up i ran a getto intake im going to get a real one tomarrow could that b the problem
Old 02-13-2010, 02:38 AM   #7
kamikazemkiii
kamikazemkiii is on a distinguished road
what are your mods?
kamikazemkiii is offline   Reply With Quote
Old 02-13-2010, 04:25 AM   #8
If it is a boost leak, ether's only going to cause a bump in the idle if the leak is so bad that it's already affecting the idle... A boost leak can be crap to track as it doesn't actually leak until there's a good amount of pressure. Google "DIY boost leak tester" or something along those lines and you'll find instructions on building a simple test kit.
If you suspect your intake piping then check it. A leak AFTER the air flow meter is what will cause your issues, not one before it... although fuel cut at only 5psi is most likely after the turbo.
Old 02-13-2010, 10:37 AM   #9
98poop
I dont have any mods on my car
Old 02-13-2010, 07:38 PM   #10
Green7mgte
Supra Forum Moderator
let me find that post. here you go. started by supralover. goes over some basic boost leak testing
http://www.toyota-supra.info/forums/mkiii-supra/16001-weird-boosting.html
and this one will really help you http://www.fd3s.net/boost_problems.html
lol phonetic alphabet my favorite is Wisky Tango.. (aka WT)
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Wont accelerate under boost, misfires, backfires, and wont idle Andrew - turbo a MKIII Supra 1 07-24-2009 01:39 PM
wont hold boost Supraman MKIII Supra 12 04-19-2007 04:52 AM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
installing manual boost controller 1989?? hamburgler MKIII Supra 4 07-13-2005 12:55 PM
No boost in neutral but boost in gear! edgardo MKIII Supra 5 10-09-2004 04:01 AM
