Old 03-02-2010, 12:46 AM   #11
907mge
907mge's Avatar
and also knock is the fuel/air mixture igniting too early?
Old 03-02-2010, 03:01 AM   #12
After seeing the head and intake apart i see where the exhaust gas comes from, going from the back cylinder to the y pipe. What i also noticed is the huge amount of carbon in the intake. Isn't that bad for air flow?
Um.... then clean it out?
That's one cause of a knock... Definitely, knock is whenever a rod bearing comes into contact with the crank. This can occur from the fuel ignition too early (a couple causes for this: preignition or autoignition, poor spark timing, detonation can contribute, excessive heat) or from the fluid bearing failing allowing the metal to come into contact from the loss of hydromatic pressure.
Old 03-02-2010, 03:10 AM   #13
907mge
907mge's Avatar
if the egr was eliminated would the intake not stay clean?
Old 03-02-2010, 04:06 AM   #14
No, not really. The PCV system is the primary contributor to any sort of detritus in the intake... if it bothers you add a catch can... we've already covered the reasons not to remove the EGR, if you still absolutely must find a reason to justify doing so then forget the justification and just remove it. But as for the dirt thing... it took 20 years for whatever carbon you're seeing to accumulate from the EGR system. Clean all the EGR passages out thoroughly and worry about it again in 15 years.
engine removal mizuboi MKIII Supra 11 06-10-2011 06:25 AM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
Alternator belt removal and installation! ~*B Magical*~ MKIII Supra 11 03-13-2008 07:27 PM
Is this true? Fuse removal can change limiter jdbones Non-Generation Specific Questions 0 12-30-2007 10:31 AM
