Old 02-21-2010, 09:26 AM   #1
91ma70
91ma70's Avatar
91ma70 is on a distinguished road
Default Trip meter not working?
Trip meter doesn't seems to work but my odo still functions? Does any one know a solution to try to fix it? Also, do you guys recommend resurfacing the flywheel when doing the clutch?
91ma70 is offline   Reply With Quote
Old 02-21-2010, 09:39 AM   #2
The linkage for the reset button is the most common point of breakage on the trip meter; Repair for this generally requires a donor unless you're good at welding plastics. Sometimes, the spindle which carries the number wheels will break loose preventing contact with the drive gear... this can usually be glued back in place.
Resurfacing the flywheel is essential.
air flow meter Cliff Non-Generation Specific Questions 0 07-21-2009 04:16 PM
Cigarette Lighter not working Ogheen MKIII Supra 1 05-21-2009 08:52 PM
Headlights not working SilenceboneSupra MKIII Supra 1 01-08-2009 10:08 PM
Broken trip odometer? carodz MKIII Supra 6 07-14-2008 11:56 AM
