#1 |
There is a green light that goes around the key hole in the ignition. I stays on all the time. Can someone direct me to the cause? Also the floorboard light under the dash on the drivers side stay on also. Thanks for any help.
#2 |
![]() Toyota Racing Development Join Date: Apr 2007
Does the dome light come on and turn off properly when the doors are closed? (when it's set to the right mode, naturally)
There are only a couple possibilities, a bad door switch is the most likely.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#3 |
You were correct! Bad door switch! Did not make the connection in my head between the door and the ignition light - but it totally makes sense. Much thanks!
Thread Tools | |
Display Modes | |
Dome Light? | SuperX | MKIII Supra | 4 | 02-02-2010 11:49 PM |
check engine light & bulb light, what? | nosuprayou | MKIII Supra | 2 | 12-19-2009 09:15 PM |
Ignition write up.. | midwestmk2 | MKII Supra | 0 | 06-11-2006 02:56 AM |
battery warning light / tail lamp failure warning light | MattJ | MKIII Supra | 5 | 02-06-2006 07:22 PM |
