Old 02-23-2010, 07:57 PM   #1
supraluver4life
supraluver4life is on a distinguished road
Default replacing head gasket
so is it completely necessary to have both the block and head machined when replacing the head gasket with a composite one?
oh and im planning on replacing the timing belt and headgasket at the same time. what would be a good timing belt and a good hg?
Cusco front, Tein Rear coilovers
Massive DDP, 3'' custom catless exhaust, Tsudo muffler 4.5'' outlet, Apexi cold air intake, Act stage 3 clutch, ct26 turbo (stock)- 10psi
+300rwhp
"Not driving a car because its too nice, is like not fucking your gf so shes still tight for the next guy"
supraluver4life is offline   Reply With Quote
Old 02-23-2010, 09:08 PM   #2
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
I used a Fel-Pro and had the head only machined flat. It was only out a few thousanths. Just get the bolts up to ~70 ft.lb. with the new gasket and you should be OK. I sprayed aluminum paint heavily on both sides of the gasket--never had a problem with any HG I've replaced (~30 or so, only 1 Supra).
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
Old 02-23-2010, 10:58 PM   #3
Agreed. Also, you don't need or want as fine of a finish as is required for a MHG, it gives the head and block more surface area to hold the gasket with.
Aluminum paint?? That's a new one to me. I'd recommend one of the Hylomar gasket dressings (make sure it's one of the formulas specified for head gaskets) or a copper HG spray. The reason for using an actual gasket dressing is that they are formulated NOT to cure and will remain tacky.
Old 02-24-2010, 07:24 PM   #4
supraluver4life
alright great and what would be a good headgasket? website?
thank you for your help
+300rwhp
Old 02-25-2010, 01:23 AM   #5
907mge
907mge's Avatar
does anyone think the felpro hg is worth using? i'm getting the whole top end set for 75 from someone. I was thinking of just buying the toyota hg to put in Any suggestions?
Old 02-25-2010, 05:44 AM   #6
I've never looked at Fel Pro's HG... I've heard mixed reviews and that they, like Toyota, have made several revisions to the HG to ensure better reliability. Personally, I'd stick with Toyota for the HG and use the rest of the Fel Pro set for everything else... but that's just because I've had good results with Toyota HGs.
Old 02-25-2010, 10:00 PM   #7
supraluver4life
ya the way i see it, the stock head gasket can last ~100k miles under torqued so i think ill just go with that. how much is a stock hg approximately?
+300rwhp
Old 02-25-2010, 11:51 PM   #8
907mge
907mge's Avatar
$80 to $90 depending on where you get it, also magauto.com appears to have the cheapest oem parts from what i found
Old 02-26-2010, 12:03 AM   #9
MSRP for Toyota's HG is $113.39. Champion Toyota sells it for $86.18. I'm used to seeing them sell for about $90. The part number is: 11115-42021
Replacing the Head Gasket SupraDietrich MKIII Supra 17 11-09-2005 01:57 AM
