Old 02-23-2010, 08:29 PM   #1
BlueTuner
BlueTuner is on a distinguished road
Default Accel pedal broken
So i was driving on the road, and i hit the gas pedal. All the sudden the pedal goes soft. I can press down the pedal like nothing is there, I get home and i look at the engine, the metal line that goes from the pedal to the throttle thing are over laping. If you have no clue what im talking about heres a better discription. Push pedal, which pulls the line, which moves these things bolted on the engine, which moves a rod that opens and closes the throttle body part. The part between the gas pedal line and rod, became over lapping, it looks like a washer is missing, how does this happen. I will try to get a picture so it makes more sense.
BlueTuner is offline   Reply With Quote
Old 02-23-2010, 11:03 PM   #2
Confusing as hell... Did the cable come off the pulley? Did the pulley come off the bracket? Did the linkage come off the throttle body's pulley/lever or off the lever on the pulley bracket?
Definitely need to post pics. I would think reassembly would be obvious, so I'm not getting something.
clutch pedal problem StonecoreTx MKIII Supra 6 01-07-2010 07:19 PM
Gas Pedal Problem bryanf89 MKIII Supra 4 11-26-2009 08:43 PM
Cluth Pedal sticks in freeplay range after releaseing the pedal??? fienloco Non-Generation Specific Questions 2 09-18-2008 09:43 PM
push down pedal - slow acceleration (HELP!) hockeygott MKIII Supra 7 06-30-2008 05:40 PM
Gas Pedal problems please help ;) mkiiisupra MKIII Supra 7 10-08-2007 04:13 PM
